diff
#894350
07/07/08 06:08 AM
hi would anyone be able to tell me if a diff off a 88 c22 bighorn would fit my 88 2.8 ltr any help would be great
Re: diff
[Re: kiwilad]
#894351
07/07/08 08:13 PM
I don't know what a C22 is, but here in the states there were 2 gear ratios available...most Troopers, including the 2.8Ls, had 4.56 gears...but a few with the big tire option had 4.77s, including most of the RS (short wheel base) models here. NZ versions might vary though...
Steve Carlson - 95 Trooper LS expo rig Serenity now!
Re: diff
[Re: BigSwede]
#894352
07/07/08 10:30 PM
cheers for the reply. both trucks are long wheel base one has the 2.2 litre and mine is the 2.8 probably worth a try? <img src="/forums/images/graemlins/notooth.gif" alt="" />h
Re: diff
[Re: kiwilad]
#894353
07/08/08 02:41 AM
I think all 89-97 model year 2.6, 2.8 & 3.2l gas engined troopers came with 4.56 or 4.77 (rare) gears. Anything built in 87 and 88 may or may not be interchangeable since some came with the smaller engines and smaller axles. I think they were all 4.56, but they ring bolt counts may be 8 in front 10 in rear, 10 for front and rear, or 10 in front and 12 in rear.
Re: diff
[Re: kiwilad]
#894354
07/08/08 05:35 AM
hi would anyone be able to tell me if a diff off a 88 c22 bighorn would fit my 88 2.8 ltr any help would be great I suspect that he is talking about the 2.8l DIESEL, but we will have to wait for him to respond back. As far as I know, the 2.8l GAS was only available in the U.S.
Re: diff
[Re: Jim_Paget]
#894355
07/08/08 07:16 AM
thanks for the help i suspect wareagle may be right the diff i was going to buy is off the 2.2 diesel model that came out here (nz) in 88 my trucks the same model and year except the motor mine being a 4jb1? 2.8 ltr deisel
Re: diff
[Re: kiwilad]
#894356
07/14/08 10:58 PM
In the UK the change over from the 8 bolt front and 10 bolt rear to the 10 bolt front and 12 bolt rear was 87 I believe. If they are the same year as you say they should share the same diff carriers. The ratios may be different but probably will be the same if the bighorn is a diesel. But this can be a good thing, provided you swap the both diffs!
I have petrol 4.56 diffs in my 89 Mk1 (was a 4JB1) in place of the stock 4.44 diesel diffs, compensating for the larger boots.
(apologise if I am telling granny how to suck eggs with the ratios)
1989 3.1 Isuzu Bighorn Hybrid 2" Lift with longer shocks 31.10.50R15 Recip Trials Full 2.5" free flow stainless system Front mount intercooler Pump tuned 4.56 Diffs
