Wanted: 3.4 Starter Drilling Jig #894396 07/07/08 03:08 PM
Craig Offline OP
Does anyone know of a source for a jig for drilling a 3.4 block to move the starter to the left side?
Buy a Trooper. You'll be glad you did.
Re: Wanted: 3.4 Starter Drilling Jig [Re: Craig] #894397 07/07/08 05:46 PM
Trooper-san Offline
I remember that there is such a jig. I've seen it online. I had the source bookmarked at one time, but I've lost all my bookmarks at least twice, so I no longer have it.
EdMc should be able to tell you about availability of this jig.
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: Wanted: 3.4 Starter Drilling Jig [Re: Craig] #894398 07/07/08 06:22 PM
Storm Trooper Offline
My friend and I did mine without a jig. It really wasn't very difficult. With the engine on a stand, we clamped the starter in place, made sure the drill was level and then just drilled the holes. When thats done, remove the starter, tap them and bang, thats it.
'91 Trooper
3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: Wanted: 3.4 Starter Drilling Jig [Re: Craig] #894399 07/07/08 07:52 PM
Ed Mc Offline
Here's the link:
http://www.rodneydickman.com/n101.html
p.s. this info is found in my "3_4 Swap Intro" writeup in the packet of swap information!
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Wanted: 3.4 Starter Drilling Jig [Re: Ed Mc] #894400 07/08/08 08:48 PM
Craig Offline OP
Thanks. I was hoping to save a few dollars and buy a used one, if one were available. I only have one block to drill so far. I guess I could invest in a new jig and offer it to the next needy Trooper owner once it's served me.
Re: Wanted: 3.4 Starter Drilling Jig [Re: Craig] #894401 07/09/08 04:40 AM
maxwell417 Offline
I / we made a paper tracing off the 2.8 block. Center punched with a punch, triple checked the measurements. Drilled & tapped came out perfect <img src="/forums/images/graemlins/smile.gif" alt="" />
More pictures http://rides.webshots.com/album/39550342dXUkDD
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Wanted: 3.4 Starter Drilling Jig [Re: maxwell417] #894402 07/10/08 04:41 AM
BillW Offline
I've got a used one (used once), will take $40.00 plus whatever the shipping is from Wichita Kansas. E-mail me with your info incl. phone # and I'l call you.
91 LS Trooper 3.4 w/225k
BillWhitbeck@grovesigncompany.com
Re: Wanted: 3.4 Starter Drilling Jig [Re: BillW] #894403 07/11/08 04:54 AM
maxwell417 Offline
Hi BillW ... good to see another Trooper guy in the Wichita area <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Wanted: 3.4 Starter Drilling Jig [Re: Craig] #894404 08/01/08 04:44 PM
Chris Perosi Offline
Isuzu Staffer Emeritus
Hey Craig, how's things? <img src="/forums/images/graemlins/smile.gif" alt="" />
When I did mine, I did the same as Storm Trooper. I remember hemming and hawwing about it for a few days first... Like Nike says, Just Do It. It's not a rocket, just a starter, don't get too worried about it. Check and double check and triple check, and it wouldn't help to have a spotter with a good eye to watch you keep the drill level and straight, but otherwise, not bad at all... I call it "Scaredy Cat Syndrome" -- where you're so scared you're gonna mess it up that you just keep putting it off. Then you do it, and you go, "Oh man, that was stupid, I could have done that weeks ago..." Just be sure of you're measurements and you'll be fine.
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Re: Wanted: 3.4 Starter Drilling Jig [Re: Chris Perosi] #894405 08/04/08 04:57 PM
Craig Offline OP
Thanks, Chris. Sean Michael left me his jig before he left for Logan. That should make the job simple enough that I can do it. Keeping the bit perpendicular is much easier with a guide.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6325 MB (Peak: 0.7372 MB) Data Comp: Off Server Time: 2026-05-27 17:03:45 UTC
