1994 passport v6 A\T #894603 07/08/08 04:15 AM
harleystroker2 Offline OP
I am having trouble with my Passport. When I try to put it in 4wd the light does go on on the dash but I don't think the transfer case is actuating and when I try to move the actuator to 4wd low the handle will move up to the proper position but it will not move over to the side to shift into low, it will not even go far enough over to pull down on the handle. Any ideas would be appreciated.
Thanx-
Bob K.
Re: 1994 passport v6 A\T [Re: harleystroker2] #894604 07/09/08 12:14 AM
bamashooter Offline
I don't know the answer to your question, however, if you don't get an answer soon, try posting your problem at http://forum.planetisuzoo.com/. Like this forum, there's good folks waiting to help. Just happens to be more of them. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 1994 passport v6 A\T [Re: harleystroker2] #894605 07/13/08 03:30 AM
Van Offline
Does 4Hi work? Manual locking hubs? Have you checked the transfer case fluid? Have you used the "Search" function?
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: 1994 passport v6 A\T [Re: Van] #894606 07/13/08 05:14 AM
Jaybird323 Offline
not to sound mean or anything but is it in nutrual or park? Sometimes its the smallest things.
1994 Isuzu Rodeo 4x4. Indy4x lift shackles in rear, cranked bars in front. 1 1/2" lift on 31" Pathfinder a/t
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5998 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-07-15 00:09:47 UTC
