1994 passport v6 A\T
#894603
07/08/08 04:15 AM
I am having trouble with my Passport. When I try to put it in 4wd the light does go on on the dash but I don't think the transfer case is actuating and when I try to move the actuator to 4wd low the handle will move up to the proper position but it will not move over to the side to shift into low, it will not even go far enough over to pull down on the handle. Any ideas would be appreciated. Thanx- Bob K.
Re: 1994 passport v6 A\T
[Re: harleystroker2]
#894604
07/09/08 12:14 AM
I don't know the answer to your question, however, if you don't get an answer soon, try posting your problem at http://forum.planetisuzoo.com/. Like this forum, there's good folks waiting to help. Just happens to be more of them. <img src="/forums/images/graemlins/patriot.gif" alt="" />
#894605
07/13/08 03:30 AM
Does 4Hi work? Manual locking hubs? Have you checked the transfer case fluid? Have you used the "Search" function?
HTH Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4 NEVER give up...
[Re: Van]
#894606
07/13/08 05:14 AM
not to sound mean or anything but is it in nutrual or park? Sometimes its the smallest things.
1994 Isuzu Rodeo 4x4. Indy4x lift shackles in rear, cranked bars in front. 1 1/2" lift on 31" Pathfinder a/t
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5998 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-07-13 09:34:41 UTCValid HTML 5 and Valid CSS
