Brakes going from Gen I to Gen II #894836 07/09/08 05:18 PM
jdchappell Offline OP
I've heard about alot of the gen 1 trucks putting on gen 2 brakes on here. I would assume they are bigger and that is why. I am running 33's and need the stopping power. Plus my brake pad fell off last night at the shop. I plan on a complete brake overhaul this weekend, what all do I need in order to make this conversion? the rear shoes will stay the same? Do I just get pads and rotors for the front from a Gen II. I am not sure, but willing to listen. please advise. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Brakes going from Gen I to Gen II [Re: jdchappell] #894837 07/09/08 07:40 PM
jfarsang Offline
This is a post I did up on another forum (same applies here):
Have to apologize about the pics. I had to toss 1/2 of them because they went all weird on me.
Here's the goodies.
It's a direct bolt-on except two things :
1. shield has to be cut (top/bottom) about 2 inches to allow for the larger (longer) mounting bracket
2. brake line mounting plate onto the caliper is different. I just took it off. Doesn't make any difference.
As for the Superwinch manual hubs, I prefer manual hubs over auto's. I like to know that when it's off, it's off. When it's on, it's on. As well as manual hubs tend to be more reliable as there are fewer moving components internally and they are more robust. Downside is you have to get out of your vehicle to engage/disengage them.
Superwinch hubs from summitracing online in the US. $120 shipped
I bought all the brakes gear
-Raybestos Professional Grade calipers (semi-loaded = comes with slider pins,mounting brackets, pad mounting clips)
-Raybestos Professional Grade ceramic pads
-Raybestos PG Calipers
All are spec'd for a 1992 Mitsubishi Montero Sport
Jesse
:M
[img]http://img524.imageshack.us/img524/4140/dsc0109kw4.jpg[/img]
[img]http://img58.imageshack.us/img58/8238/dsc0110wm5.jpg[/img]
[img]http://img258.imageshack.us/img258/8463/dsc0111jo3.jpg[/img]
[img]http://img78.imageshack.us/img78/7350/dsc0112ui3.jpg[/img]
[img]http://img48.imageshack.us/img48/7441/dsc0114ui3.jpg[/img]
[img]http://img514.imageshack.us/img514/3949/dsc0115sk3.jpg[/img]
[img]http://img208.imageshack.us/img208/7281/dsc0116oq6.jpg[/img]
[img]http://img398.imageshack.us/img398/2672/dsc0119ri0.jpg[/img]
[img]http://img242.imageshack.us/img242/6520/dsc0120gt1.jpg[/img]
[img]http://img58.imageshack.us/img58/4089/dsc0121ve3.jpg[/img]
[img]http://img258.imageshack.us/img258/3640/dsc0123vp4.jpg[/img]
[img]http://img48.imageshack.us/img48/9898/dsc0125nz2.jpg[/img]
[img]http://img242.imageshack.us/img242/345/dsc0126qa5.jpg[/img]
[img]http://img78.imageshack.us/img78/723/dsc0128zb0.jpg[/img]
[img]http://img48.imageshack.us/img48/4485/dsc0130kp9.jpg[/img]
[img]http://img295.imageshack.us/img295/839/dsc0131ab9.jpg[/img]
[img]http://img242.imageshack.us/img242/1664/dsc0135ct8.jpg[/img]
[img]http://img440.imageshack.us/img440/8949/dsc0136xe1.jpg[/img]
[img]http://img258.imageshack.us/img258/7180/dsc0138vw8.jpg[/img]
[img]http://img514.imageshack.us/img514/6913/dsc0139hr4.jpg[/img]
[img]http://img514.imageshack.us/img514/696/dsc0140di8.jpg[/img]
[img]http://img242.imageshack.us/img242/9190/dsc0143jt9.jpg[/img]
[img]http://img440.imageshack.us/img440/8167/dsc0145aw0.jpg[/img]
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on
89 Montero - Project
92 Pajero Exceed - Gone to a good home
92 Delica Chamonix - Gone to a good home
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.5962 MB (Peak: 0.6602 MB) Data Comp: Off Server Time: 2026-11-17 11:01:04 UTC
