Page 2 of 4 1 2 3 4
Re: Isuzu Trooper Engine Problems [Re: wondergeek] #895299 07/17/08 01:48 AM
rong Offline
need more eng info ? MFI or carb 2.6 LS sounds like fuel via cpu info off if not vac leak on tbi sys
my red trooper #2 <http://live.yahoo.com/hillbillyso_uthtx11>
Re: Isuzu Trooper Engine Problems [Re: wondergeek] #895300 07/17/08 01:58 AM
rong Offline
ck for clogged fuel pick up tube on tank u can change all the filters u want if pump can't move it can't get there
Re: Isuzu Trooper Engine Problems [Re: wondergeek] #895301 07/17/08 03:47 AM
G
generation_one Offline
It isn't that,
sure it is. set up based on slipped balancer as reference.
Topical:
http://wiki.answers.com/Q/How_do_you_set_the_engine_timing_for_a_1996_honda_passport
I had the same problem with a '89 Trooper last year...took two weeks to change timing belt
I will be going through this with a '89 pickup in the next day er two. I hope my low compression is just valve timing related and not worse
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Isuzu Trooper Engine Problems [Re: generation_one] #895302 07/17/08 07:24 AM
wondergeek Offline OP
That is all mine problem is is a valve timing issue.
Keith Asche
1988 Isuzu Trooper II
2.6Liter I-Tech MPFI I-4
S Model
182,451
Brittany Blue Metallic
http://www.cardomain.com/ride/3110466
Re: Isuzu Trooper Engine Problems [Re: wondergeek] #895303 07/23/08 06:38 AM
Well it is timed correctly now but it still doesn't idle. I am thinking it is a vacuum leak(s) somewhere. I am getting the power steering fixed today, and am going to try to get a vacuum meter. <img src="/forums/images/graemlins/frown.gif" alt="" />
Keith Asche
S Model
182,451
Re: Isuzu Trooper Engine Problems [Re: wondergeek] #895304 07/23/08 02:11 PM
Another question I have is where can you get new mounts for the front vent windows and how to remove and install said components. My top mounts on both front door vent windows have both broken. Thanks
Keith Asche
S Model
182,451
Re: Isuzu Trooper Engine Problems [Re: wondergeek] #895305 07/24/08 02:34 AM
maxwell417 Offline
Circled in green are where the screws are. By mounts do you mean the hinge? I replaced my wingvent rubber seals from St Charles Isuzu, they likely can get anything you need.
http://isuzu.stcharlesauto.com/Department-Parts.aspx
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Isuzu Trooper Engine Problems [Re: maxwell417] #895306 07/24/08 09:24 AM
By mount, I mean the top pivot point where there is the screw that holds the glass to the mount. That part on both windows has broken. On the engine note, I am going to need an overhaul.
Keith Asche
S Model
182,451
Re: Isuzu Trooper Engine Problems [Re: maxwell417] #895307 08/18/08 07:22 AM
I mean the top hinge point.
Keith Asche
S Model
182,451
Re: Isuzu Trooper Engine Problems [Re: wondergeek] #895308 08/18/08 11:17 AM
Van Offline
Go here to find the part #.... http://www.myisuzuparts.com/
Sources for the part are.....
Jerry... PM JLEMOND on this forum.
Read this post.... http://forum.planetisuzoo.com/viewtopic.php?t=18448
Or here.. http://isuzu.stcharlesauto.com/Specials-Parts.aspx
Or here.. http://www.allhyundaiisuzuparts.com/
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6473 MB (Peak: 0.7681 MB) Data Comp: Off Server Time: 2026-05-29 14:56:30 UTC
