Steering Column Components #895323 07/12/08 03:21 PM
hlhneast Offline OP
Anybody know where I can find a good pic of the parts from the top of a steering column? I got a tilt column out of a junker and have successfully rebuilt most of it but I dont know exactly what I am missing on top. There is a white part that has a spring loaded pin it it which I assume is for horn continuity. There is also a plate that has the look of a fan sorta. Anyway, when I put the parts together, the pin catches on the steering wheel and locks it up. I need to know what I am missing so I can use the column. Anybody out there have a column that is pulled apart who can send a pic? The factory service manual's pic is crap, and I cant tell anything from it. I may have to go to a U-Pull-It yard and take a GM tilt apart if no one can help out. I may have to anyway to get the missing parts. Thanks! <img src="/forums/images/graemlins/notooth.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
Re: Steering Column Components [Re: hlhneast] #895324 07/13/08 12:46 AM
BobRowe Offline
Try a Haynes CJ manual for a good picture.
BTW, the "fan" looking plate is called a lockplate.
The white thing with the spring loaded button for the horn is called a cancellation ring. That white thing also operates against the turn signal detents to cancel the turn signal after the steering wheel has been turned a certain amount.
When you install the cancellation ring, it must be installed such that it can turn. If you look at the lockplate, it will be obvious where the horn button must stick up through.
BTW, you can get new cancellation rings from OMIX-Ada, but they will be empty. That is, they will have the copper ring on the bottom, but the metal button, the button keeper, and the button spring will not be included. I haven't been able to locate a seller of those small parts, and I have had to fabricate my own. The spring and button are easy to make -- it's the button keeper that is a PITA.
Re: Steering Column Components [Re: BobRowe] #895325 07/14/08 11:37 PM
hlhneast Offline OP
Bob, do ya happen to have this Chiltons? If so can you scan that diagram fer me? Anybody else got one? Probly 'bout all of the 76-86 are the same. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Steering Column Components [Re: hlhneast] #895326 07/15/08 03:34 AM
Brown81CJ5 Offline
The Haynes manual I have does not really have a good pic of it. When I had to do work on my column, a buddy of mine gave me a link to a site that had step by step instructions with LOTS of pics. I will talk to him and see if he stills knows what the website is.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Steering Column Components [Re: hlhneast] #895327 07/16/08 05:13 AM
BobRowe Offline
No, I don't have a Chilton's manual.
Re: Steering Column Components [Re: Brown81CJ5] #895328 07/19/08 06:20 PM
hlhneast Offline OP
Thanks, Brown, that'll be a big help. I am suprised the Jeep FSM's pic is so crappy and I hate to go to a U Pull It and tear apart a column just to look. If they catch me I will be buying it probly, lol. There isnt much around my house so I will wait til I get back to FL. I am still hoping to get a good pic from someone on the board. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Steering Column Components [Re: BobRowe] #895329 08/03/08 09:33 PM
A
AZJeepdog Offline
I recently aquired a factory Technical Service Manual for the "82"-"83" CJ's and would be happy to send you the expoded views of the Tilt column if you still need it.
EG
Re: Steering Column Components [Re: AZJeepdog] #895330 08/04/08 03:59 PM
O
oldgreen Offline
try looking in the back of a 4wd hardware catalogue, there are some pretty good pics of the jeep parts there.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6223 MB (Peak: 0.7176 MB) Data Comp: Off Server Time: 2026-06-23 01:19:03 UTC
