Front end maintainence #895770 07/16/08 03:55 AM
J_Bird Offline OP
I'm ready to replace the front wheel bearings. My question is about the brake pads housing. They are plumbed with a hard line, going to a bracket. Then changing to a flex hose.
I dont think I can just remove the bolts holding the bracket and hang with a bungie, because of the hard line. The brakeline bracket is bolted through the steering knuckle. I'm afraid to unbolt this bracket.
I may just disconnect the brakeline from the caliper. I hate dealing with the brake fluid while doing the other work.
Any advice would be appreciated. J.B.
J-Bird
'95.5 T, SR5, Bone stock w/32x11.50's
'06 Sonata LX
Re: Front end maintainence [Re: J_Bird] #895771 07/16/08 03:49 PM
ErikB Offline
Toyota Moderator
Trying to remove the large bolts holding the steering arm to the kunckle (that the brake line bracket is under) is REALLY difficult since the factory used red locktite and they are large bolts.
What Ive always done on my vehicles and others I've worked on is unclip the hard line from the bracket and moved it to the side as far as I can, and then cut a slot in the bracket with a grinder so that the hard line can be slipped out (try not to nick the line with the grinder :p ).
http://home.4x4wire.com/erik
Re: Front end maintainence [Re: ErikB] #895772 07/16/08 05:29 PM
jmoser Offline
:p ).
Red Loctite releases via applying heat - if you gently warm up the bolts with a propane torch it will let go.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: Front end maintainence [Re: jmoser] #895773 07/17/08 03:21 AM
J_Bird Offline OP
Your not kidding. I got one of those bolts loose. The other was a no-go. Thanks for the advise. I'll try tomorrow.
J-Bird
'06 Sonata LX
Re: Front end maintainence [Re: J_Bird] #895774 07/19/08 05:32 AM
surlynkid Offline
i've always used impacts with no problem.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Front end maintainence [Re: surlynkid] #895775 07/20/08 03:57 AM
J_Bird Offline OP
Finished up the bearings today. My roar seems to be gone. I only put about 5 miles on it. Had to go to the beach, for our anniversary dinner(20 yrs.) Anyway, all seems well.
My impacts wont fit in there by the way. I just unscrewed the brake line at the caliper. Put a wire nut on it. Not too messy.
Thanks for the advice.
J-Bird
'06 Sonata LX
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6066 MB (Peak: 0.6762 MB) Data Comp: Off Server Time: 2026-10-21 20:17:38 UTC
