Harmonic Balancer Removal Problem #895783 07/16/08 06:08 AM
sfr4dr Offline OP
See sig for model. I am having major trouble getting the center bolt out of the harmonic balancer (one that bolts into the crank). I even sprayed some lube on it and let it sit a few days. I even snapped off one of the two threaded puller inserts on the harmonic balancer while I had something wedged in there to keep the engine from rotating. I don't see any place on the flywheel to keep the engine from rotating. Is there some access place and a tool for this? I also thought about trying to use an impact gun but there is no clearance to get the tool in there. I doubt even removing the radiator would give me enough room. Any suggestions?
1995 Rodeo V6 4WD
Re: Harmonic Balancer Removal Problem [Re: sfr4dr] #895784 07/16/08 06:34 AM
Madcat Offline
Put a wrench with a cheater bar on it and set it on the frame or the ground, then turn the engine over with the starter.
Jim
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Harmonic Balancer Removal Problem [Re: Madcat] #895785 07/16/08 06:22 PM
sfr4dr Offline OP
I thought about that but figured that could damage the starter???
1995 Rodeo V6 4WD
Re: Harmonic Balancer Removal Problem [Re: sfr4dr] #895786 07/16/08 08:02 PM
mlclark Offline
Isuzu Moderator
I'm not a fan of the starter method. It works, but there is just too little control for my tastes.
If you really can't get the engine to stay still with it in gear and the parking brake on, then pull a spark plug, rotate the engine so that piston is somewhere near the bottom of its stroke. Then feed in some 1/4" cotton rope to fill the cylinder. Rotate the engine until it locks everything up. Don't forget to leave a tail of rope out of the hole or you will have bigger problems.
Good Luck,
Michael
Re: Harmonic Balancer Removal Problem [Re: mlclark] #895787 07/16/08 11:06 PM
sfr4dr Offline OP
Hmmm. Sounds like that could work but if the cylinder was on an exhaust stroke then the rope would be jamming up against an open valve. That's not a good thing.
1995 Rodeo V6 4WD
Re: Harmonic Balancer Removal Problem [Re: sfr4dr] #895788 07/17/08 01:14 AM
mlclark Offline
Isuzu Moderator
Put it in what every part of the cycle you want, but it really doesn't make a difference. 1) with enough rope, it will be against the rest of the head too and 2) you are not cranking on it with enough umph, nor speed. If you can bend a valve, via a breaker bar on the crank with cotton rope as a cushion, you are a stronger man than I.
Good Luck,
Michael
Re: Harmonic Balancer Removal Problem [Re: mlclark] #895789 07/17/08 06:23 PM
sfr4dr Offline OP
Well I reluctantly tried the starter method and it worked! I figured it would either break the starter or work. I pulled the timing chain cover off and the timing belt tensioner is the culprit of the knocking noise. Now I just need to remove it and figure out what is wrong with it and replace it.
1995 Rodeo V6 4WD
Re: Harmonic Balancer Removal Problem [Re: sfr4dr] #895790 07/18/08 03:31 AM
bamashooter Offline
Now that you have the pain in the butt work done, go ahead and replace the belt and tensioner if the belt hasn't been replaced in a while. There may be other maintenance tasks you can perform while you're that far along. I'm not familiar enough with your motor to offer suggestions; I'm sure others here can chime in.
Re: Harmonic Balancer Removal Problem [Re: bamashooter] #895791 07/18/08 05:30 AM
Madcat Offline
Replace the tensioner, timing belt. And for preventative maintenance the water pump, and check for oil leaks at the cam/crank seals.
Jim
Re: Harmonic Balancer Removal Problem [Re: Madcat] #895792 07/18/08 06:24 PM
sfr4dr Offline OP
Well I have pulled the tensioner and pulley and they show no obvious problems. They look pretty good actually. The timing belt is pretty crusty so I am going to get a new one. Now I am not sure where what was causing the problem. When I ran it with the cover off the tensioner pulled was shaking at the same rate as the sound so it really appeared that's where the sound was coming from. The bearing on the pulled and the pivot bushing look good. The tensioner has descent tension but I wonder if it was stronger when new. I suppose I can replace that too. What do you guys suggest? Maybe replace those two parts, put the belt on, and see what happens.
On a side not the marks on the timing belt did not match up with the ones on the cam pulleys and the crank pulley even before I took the belt off. The lame Chiltons I have said there was a change from 1995 to 1995.5 on where the alignment marks are on the timing belt back cover. Have you guys ran into that? I just need to be sure the new belt has the correct marks for my year which is a 95.
1995 Rodeo V6 4WD
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6412 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-05-29 23:57:27 UTC
