Cherokee shocks #896400 07/20/08 03:13 PM
BigR61 Offline OP
Hi, I have a 98 Cherokee Sport 4.0 that is stock. I changed the shocks less than a year ago. I installed the Monroe Sensa-trac front and rear. lately the suspension has become "stiff and jumpy" when you go over the concrete unions on the road or any uneven condition. This vehicle is used by my wife to take the kids to school and get the groceries so it has not been off roading. Do I need to replace the shocks again or do something to the rear leafs? <img src="/forums/images/graemlins/confused.gif" alt="" /> Thanks.
90 Cherokee Laredo
98 Cherokee Classic
www.cardomain.com/ride/2986792
Re: Cherokee shocks [Re: BigR61] #896401 07/20/08 03:46 PM
BobRowe Offline
Sounds like shocks. You might try Rancho adjustable shocks.
Re: Cherokee shocks [Re: BobRowe] #896402 07/20/08 09:26 PM
BigJim Offline
How muxh air are you running in the tires... THEY are your first shock absorber.. You shouldn't feel the dividers in the road due to the tires themselves..
Re: Cherokee shocks [Re: BigJim] #896403 07/20/08 10:43 PM
BigR61 Offline OP
Tires are 235/75/15 and have allways kept them around 32 lbs. Haven't changed anything on the vehicle since I changed the shocks.
90 Cherokee Laredo
98 Cherokee Classic
Re: Cherokee shocks [Re: BigR61] #896404 07/20/08 10:52 PM
BigJim Offline
In my ENTIRE life I haven't heard of shocks getting HARDER till your post. Could it be that you don't ride in her vehicle much and so you are NEW to the ride of those shocks? Traditionally shocks get weaker..but not harder as they grow older. MODERN shocks last 150K most times. My wifes had 160K on them when we traded the ride off and they were stock shocks. They might have been a bit softer than new but little if any at all.
Re: Cherokee shocks [Re: BigJim] #896405 07/20/08 11:25 PM
BigR61 Offline OP
I never heard it either, that's why I thought I ask you guys. We have had it for 2 years and I drive it on weekends when the whole family goes out and it just started feeling different. It doesn't wobble like when the shocks are worn. I guess we'll just have to get use to it. Thanks.
90 Cherokee Laredo
98 Cherokee Classic
Re: Cherokee shocks [Re: BigR61] #896406 07/21/08 04:07 PM
DBL_DTY97TJ Offline
Might the neoprene eyeholes be going south? They shouldn't be yet, but worth a look. Or could a shock have been damaged somehow so that it's binding up?
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Cherokee shocks [Re: DBL_DTY97TJ] #896407 07/29/08 09:36 PM
Seattlegti Offline
The polyurethane upper shock bushings in my Cherokee settled 1/8" or so after a few thousand miles. Might be worth cranking the top caps down nice and tight and checking the bottom bushings for play.
Doubt thier blown if you've just be driving on pavement. Even my $25 Skycrackers lasted 2 years off roading.
It's pretty easy to damage one of the rear shocks backing into stuff off road. The other is in front of the axle so hard to hit. Again, if your on pavement I doubt you've bent a shock.
Could be one or more worn steering components are making your ride rougher than usual.
Might try shaking the front tires while thy're off the ground to see if they rattle or have any play.
Loose track bar, pitman arm, ball joints,wheelbearings, steering stabilizer, can all cause rough handling or even the dreaded Jeep Death Wobble <img src="/forums/images/graemlins/evil.gif" alt="" />
Been there, super sucks to hit a pothole and start fishtailing wildly at 45MPH in thick traffic. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Cherokee shocks [Re: Seattlegti] #896408 08/04/08 03:07 AM
PartyTruck Offline
My '00 WJ has just 65k on it, most of it on pavement and all of the shocks are gone bad, and to my knowledge they came with monroe's from factory. I you decide to swap out again then try KYB, they are in a whole different league than Monroe.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6280 MB (Peak: 0.7318 MB) Data Comp: Off Server Time: 2026-06-07 07:26:10 UTC
