86 toyota 1 ton 22re, takes a lot of cranking to start? fuel pump ? #896412 07/20/08 04:29 PM
moto629 Offline OP
i've got a 86 1 ton with a 22re, runs great, but when starting cold after sitting a few days , it take a lot of cranking to start it, Im guessing the fuel system is bleeding off pressure somewhere, maybe through the fuel injection pump in the fuel tank ? there are no external leakes anywhere so it must be back through the fuel tank ?? I dont have much troubleshooting experience with the FI 22r's, all my others are carburated ! thanks !
Re: 86 toyota 1 ton 22re, takes a lot of cranking to start? fuel pump ? [Re: moto629] #896413 07/20/08 09:26 PM
4Crawler Offline
Try the fuel pump test jumper for starters:
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Re: 86 toyota 1 ton 22re, takes a lot of cranking to start? fuel pump ? [Re: 4Crawler] #896414 07/20/08 10:37 PM
Richards19884x4 Offline
BTW, Roger: This trick did fix my starting problem as well on my 88 22RE. But since the AFM and Circuit Open Relay passed all the listed tests, does that mean the fuel pump itself may be failing? Is it possible for the open circuit relay to pass the test, but still be faulty, as you suggested in your article? Just curious. And not intentionally hijacking the thread.
I also wanted to ask what others were using for jumpers on the diagnostic connector on the PS fender. I tried several different size wires and they either kept coming loose or just wouldn't make a good connection. A trip to Radio Shack proved useless. I found a box of electrical jumpers, like for a circuit board. Twisting the ends of 3 of these together seemed to be just about the right size to fit tightly and make a good connection, but it sure looks hokey.
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: 86 toyota 1 ton 22re, takes a lot of cranking to start? fuel pump ? [Re: Richards19884x4] #896415 07/21/08 12:19 AM
4Crawler Offline
Have heard one of the coils on the CO relay can get weak over time and not pull in the CO relay contacts hard enough to make good contact. I had something like this on my '85 with the starter coil and ran with the jumper installed for a few years. Then one day I pulled the jumper and found the relay was working fine (and has ever since).
I used a pair of spade lug connectors on the end of a short length of wire in mine (older style connector):
But later replaced the jumper with a switch:
Of course since doing that, have not had a problem with the CO relay or fuel pump.
Re: 86 toyota 1 ton 22re, takes a lot of cranking to start? fuel pump ? [Re: Richards19884x4] #896416 07/21/08 03:54 AM
RatLabGuy Offline
I use a paperclip, bent into a "U"... sometimes have to dig the tips around in there to clean out the contacts, but it works every time. Cheap, easy, and available.
Question Reality.
Re: 86 toyota 1 ton 22re, takes a lot of cranking to start? fuel pump ? [Re: RatLabGuy] #896417 07/21/08 12:31 PM
Aww, c'mon. You can make it sound a little harder than that. Pretend it takes a "special kind" of paper clip or something.
Richard S.
Re: 86 toyota 1 ton 22re, takes a lot of cranking to start? fuel pump ? [Re: Richards19884x4] #896418 07/22/08 02:47 AM
BROWNBAGG Offline
cold start injector and fuel regulator, get them from a junk yard. not cheap.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6240 MB (Peak: 0.7159 MB) Data Comp: Off Server Time: 2026-05-30 01:18:37 UTC
