trooper question
#896550
07/21/08 02:40 PM
Hey everyone, without a service manual i dont know the names, but there is a nut that u tighten after u remove the lock outs that tighen the assembly, it was a lock washer with it also, do u need a special tool to tighter this?
Re: trooper question
[Re: rhouser]
#896551
07/21/08 04:35 PM
i call it the front wheel/hub nut... and no, you don't need a special tool, you should be able to spin it using a screwdriver. how tight you make it determines wheel preload. if you want to be exact, you'll need a spring scale, attach to one of the wheel lugs, and measure how much force it takes to turn the wheel. IIRC, it should be something like 7 ft-lbs, but I mostly do this by feel now adays.
-Rob
[Re: RobG]
#896552
07/22/08 12:54 PM
i need the locking washer that goes with it, u know of a place to get one? its about the size of a can of chew and maybe 3mm thick
[Re: rhouser]
#896553
07/23/08 12:18 PM
is likely going to be a dealer only part.
-Rob
[Re: RobG]
#896554
07/23/08 04:03 PM
[Re: lttlbddy]
#896555
07/23/08 06:31 PM
well untill i get my service manual i dont have a part number i even what the thing is called, i was told its a 4 dollar part
[Re: rhouser]
#896556
07/23/08 07:49 PM
you don't need a part number, just a call and a good description (lock washer in front of hub nut) should be enough. or better yet, stop by your local dealership's parts department and you can look over the guys shoulder at their book and identify it on the exploded parts diagram.
-Rob
[Re: RobG]
#896557
07/23/08 08:24 PM
A isuzu dealer or are they owned by someone else now
[Re: rhouser]
#896558
07/23/08 08:35 PM
no, an isuzu dealership, they still exist. or you could call St. Charles Isuzu if you'd rather, they've always been helpful to people on this board http://isuzu.stcharlesauto.com/for that matter, you could go to honda dealership and just lie and say you have a passport or slx. -Rob
[Re: rhouser]
#896559
07/24/08 01:06 AM
Go here and locate your part/part number. If you need help navigating through this, give me a holler. shooter http://www.myisuzuparts.com/
