Fuse link issue Gen 1 #896997 07/23/08 04:58 PM
bigroxydog Offline OP
I have been losing my alternator battery recharging on my 88 SWB. I went to Auto Zone and when they attached their test device to the battery it indicated that my alternator was putting out less than 12 volts. I returned my rebuilt alternator back to the shop that R&R the unit. and it appears the single wire connection is arcing. Installed a spare alternator on the truck and the same thing is happening again. Alternator man says my fuse link is bad and needs to be replaced. I noticed when I changed the alternator the single wire connector had some rust on it. Any ideas on how to find out what is causing this problem?
Re: Fuse link issue Gen 1 [Re: bigroxydog] #896998 07/23/08 09:01 PM
LRJ4x4 Offline
Did you replace the fuse link because that would be my guess. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Fuse link issue Gen 1 [Re: LRJ4x4] #896999 07/23/08 11:41 PM
What do they mean by the fuse link. Does that mean I have a short in the single wire somewhere and I need to replace the wire or does that mean I have to change out a fuse in the fusebox? I have read in previous posts that there is a 90-100amp fuse somewhere in the truck is that the fuse link?
Re: Fuse link issue Gen 1 [Re: bigroxydog] #897000 07/24/08 01:06 AM
CapnCrunch Offline
Driver's side of the engine bay, just forward of the clutch reservoir (assuming you have a manual tranny) on the side of the compartment.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Fuse link issue Gen 1 [Re: CapnCrunch] #897001 07/24/08 01:15 AM
Capn, the truck is an automatic, do you mean next to the brake reservoir? I see a black box in that location with three red wires and one green wire.
Re: Fuse link issue Gen 1 [Re: bigroxydog] #897002 07/24/08 10:48 PM
G
generation_one Offline
sure man, that's probably the fuse links
fuse links are like fuses. replace like with like.
i think they use one guage smaller wire that thet used in the circuit
I dont see how fuse links could be a problem unless it is open (burned) maybe poor connections is the deal..
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Fuse link issue Gen 1 [Re: generation_one] #897003 07/25/08 02:18 AM
Thanks for your help. I am going to pick up the rebuild alternator from the shop tomorrow. They replaced the stud that snapped off when I backed off the one wire stud nut. The wire connection was arcing. I am going to switch out the existing alternator this weekend for the third time. I think I am down to 40 minutes on pulling the AC compressor, compressor bracket and changing out the alternator. I think the first time I did the job it took 2 hours. I will this time inspect the charging wire plus the fuse link to see if there are any signs of bare wire or corrosion.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6139 MB (Peak: 0.6922 MB) Data Comp: Off Server Time: 2026-06-20 19:16:28 UTC
