92 paj with problem-cracked cam caps?
#897029
07/23/08 06:44 PM
More specific top end parts? This one has cam shaft caps that are cracked- Not sure why this would happen? Otherwise truck is in pretty good shape. Any reason these would fail? Anything else I should look for? I did this in the other post also. Is there anything I could use to inter change in US? I will buy this animal if it is worth it. Guy wants $2000. sending me pics. I will see either tonight or tommorrow.
Re: 92 paj with problem-cracked cam caps?
[Re: sasnydley]
#897030
07/30/08 03:05 AM
Maybe the rockers were adjusted too light. Its possible the valves were tapping the tops of the pistons. Damage to the pistons if any, will usually be low but some of the rocker arms may be damaged and could break later on.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5858 MB (Peak: 0.6338 MB) Data Comp: Off Server Time: 2026-06-17 13:18:46 UTCValid HTML 5 and Valid CSS
