timming belt broke #897075 07/24/08 01:16 AM
L
lesj Offline OP
tbelt broke today on 2000 sportage. i have found instructions on replacement of tbelt and water pump.
my question is how to make sure the crank is on tdc or 180 off ? maybe pull #1 spark plug to see if piston is at top.
any input would be appreciated.
Re: timming belt broke [Re: lesj] #897076 07/24/08 07:18 AM
bombardj1 Offline
just put the crank to match up with notch and the E to line up and then the I to line up. the hard part is getting the E and I to stay put, a helper can hold them with a socket. remember only turn it the rotation direction the kiatechinfo show how this goes. it does not tell you all the stuff you have to remove to get to it. 2 helpers would be a lot better, I don't know how many miles are on yours so check the tensioners , John
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: timming belt broke [Re: bombardj1] #897077 07/25/08 01:07 AM
L
lesj Offline OP
thanks for the info . got the tbelt back on and she fired and ran well on first crank lesj <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: timming belt broke [Re: lesj] #897078 07/25/08 02:11 PM
Lou Offline
..and for the statistics..what was the mileage on engine prior to belt failure ?
Re: timming belt broke [Re: Lou] #897079 07/26/08 01:37 AM
L
lesj Offline OP
136000.00 . replaced water pump and all belts and hoses with gates products
Re: timming belt broke [Re: lesj] #897080 07/26/08 11:50 PM
Everet Offline
And be HAPPY <img src="/forums/images/graemlins/smile.gif" alt="" /> that it is a NON-INTERFERENCE motor <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> Did you also change the tension & idler pulleys?
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: timming belt broke [Re: Everet] #897081 07/27/08 10:23 AM
L
lesj Offline OP
yes i changed all idlers
Re: timming belt broke [Re: lesj] #897082 07/28/08 03:07 AM
Everet Offline
What was your total cocktail count for the job?
Re: timming belt broke [Re: lesj] #897083 07/28/08 07:18 PM
Lou Offline
...miles?...is this is the first replacement, it softens the statistics, as 1/2 of that is what is generally recommended and experienced by many..and mine has just reached 70,000 miles......
Re: timming belt broke [Re: Lou] #897084 07/29/08 02:21 AM
L
lesj Offline OP
yes this is miles. i am the second owner i purchased it at 40000 miles i replaced plugs at 95000 miles new driver window switch, new warn hubs, front brakes, tires, thinking i need rear brakes renewed.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6383 MB (Peak: 0.7420 MB) Data Comp: Off Server Time: 2026-06-20 18:15:03 UTC
