timming belt broke
#897075
07/24/08 01:16 AM
tbelt broke today on 2000 sportage. i have found instructions on replacement of tbelt and water pump. my question is how to make sure the crank is on tdc or 180 off ? maybe pull #1 spark plug to see if piston is at top. any input would be appreciated.
Re: timming belt broke
[Re: lesj]
#897076
07/24/08 07:18 AM
just put the crank to match up with notch and the E to line up and then the I to line up. the hard part is getting the E and I to stay put, a helper can hold them with a socket. remember only turn it the rotation direction the kiatechinfo show how this goes. it does not tell you all the stuff you have to remove to get to it. 2 helpers would be a lot better, I don't know how many miles are on yours so check the tensioners , John
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#897077
07/25/08 01:07 AM
thanks for the info . got the tbelt back on and she fired and ran well on first crank lesj <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: lesj]
#897078
07/25/08 02:11 PM
..and for the statistics..what was the mileage on engine prior to belt failure ?
[Re: Lou]
#897079
07/26/08 01:37 AM
136000.00 . replaced water pump and all belts and hoses with gates products
[Re: lesj]
#897080
07/26/08 11:50 PM
And be HAPPY <img src="/forums/images/graemlins/smile.gif" alt="" /> that it is a NON-INTERFERENCE motor <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> Did you also change the tension & idler pulleys? Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: Everet]
#897081
07/27/08 10:23 AM
[Re: lesj]
#897082
07/28/08 03:07 AM
What was your total cocktail count for the job? Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: lesj]
#897083
07/28/08 07:18 PM
...miles?...is this is the first replacement, it softens the statistics, as 1/2 of that is what is generally recommended and experienced by many..and mine has just reached 70,000 miles......
[Re: Lou]
#897084
07/29/08 02:21 AM
yes this is miles. i am the second owner i purchased it at 40000 miles i replaced plugs at 95000 miles new driver window switch, new warn hubs, front brakes, tires, thinking i need rear brakes renewed.
