oil leak #897218 07/24/08 04:22 PM
HuntingRig Offline OP
I put a new rebuilt 22RE in my 87 4runner and it runs great but I have a small oil leak coming from one of the bolts on my oil pump. It is the long bolt next to the pressure relief adjustment. Would that be a gasket problem?
Re: oil leak [Re: HuntingRig] #897219 07/24/08 04:28 PM
4Crawler Offline
I had a similar leak on mine, I think I found two issues, one was that I had the wrong length bolt in one or two locations. Also, had to add some FIPG sealant on the threads of one to two bolts to stop the leak.
Re: oil leak [Re: HuntingRig] #897220 07/24/08 04:49 PM
Richards19884x4 Offline
I would suspect the o-ring behind the housing. Other than the front oil seal, this is the only place oil can come out. Since the o-ring is between the oil and that particular bolt hole, I would have to venture that it is wore out or crimped. The o-ring is fragile and not always easy to handle when putting the oil pump housing on. A fine coating of vaseline, or even oil can help the o-ring stay in place while the housing is installed.
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: oil leak [Re: HuntingRig] #897221 07/24/08 05:12 PM
Staceman Offline
Here you go, straight from the Factory Service Manual. (notice the gasket sealer on the top bolt....)
Re: oil leak [Re: Staceman] #897222 07/24/08 07:10 PM
The oil is coming from the long bolt just below the bolt that is supposed to have the sealant applied to the threads.
Re: oil leak [Re: HuntingRig] #897223 07/24/08 07:15 PM
4Crawler Offline
I think that is one of the bolts I added some sealant to the threads before installing.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6101 MB (Peak: 0.6798 MB) Data Comp: Off Server Time: 2026-06-10 07:15:24 UTC
