Tire Rub After Alignment #897233 07/24/08 07:33 PM
Rodayo Offline OP
All -
I have 265 70 r16 tires on my 04 Rodeo that only ever rubbed a little and only if there was a lot of compression. Recently I had the vehicle realigned because it was pulling to the right. Now it rubs on even moderate compression. What could the alignment shop have done? I don't think my springs would have suddenly settled. Any ideas appreciated.
Thanks!
- Jim
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
Re: Tire Rub After Alignment [Re: Rodayo] #897234 07/25/08 12:37 AM
strawmyers Offline
Isuzu Moderator
Where is it rubbing? Does it look lower in the front than it did before the aligment? Adjusting the torsion bars is one way to adjust caster; so they may have done that... lowering it in the process and causing the increase in rub.
Sean Strawmyer
Re: Tire Rub After Alignment [Re: strawmyers] #897235 07/25/08 02:24 AM
Rodayo Offline OP
It seems to be rubbing in the typical spot at the edge of the fender near the door.
I wasn't aware that they might mess with the torsion bars to make it align properly. I'll have to measure it and see.
Thanks!
Re: Tire Rub After Alignment [Re: Rodayo] #897236 07/29/08 03:13 AM
94rodeo Offline
I would also suspect they moved your torsion bars. I have had that happen to me in the past.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: Tire Rub After Alignment [Re: 94rodeo] #897237 07/29/08 03:16 AM
Jim_Paget Offline
Unless you specifically tell them not to change the torsion bars, that is a "textbook" method of aligning our rigs. The other option is with shims, and that is a pain compared to adjusting the torsion bars. (The reason you rig needed an alignment was because you adjusted the torsion bars.)
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6061 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-07-14 12:26:32 UTC
