Does Seafoam lower emissions? #897270 07/25/08 12:42 AM
Mike_Glenn Offline OP
Anyone had any experience running Seafoam thru their intake manifold to clean out carbon deposits? does it work? Does it lower HC on emission tests? there are lots of stories on Youtube about it. just do a search on seafoam if you want to see them. Let me know what kind of experience you have had with it!
thanks!
'94 Montero 3.5 SR, 202,000 mi.
Re: Does Seafoam lower emissions? [Re: Mike_Glenn] #897271 07/25/08 01:27 AM
93montero_sr Offline
Try changing your spark plugs with platnum plugs, air filter and pcv valve to lower your hydro carbons.I went thru this problem before.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: Does Seafoam lower emissions? [Re: 93montero_sr] #897272 07/25/08 02:33 AM
RaiderRandy Offline
I take it you have had it tested and are high on the CO portion? I had my last one (88 2.6) and the first time round it flunked: 36k on CO particulates and limit was 25k I believe. Here's what I did: I ran the tank down to less than 1/8, went to Lowes and spent $14 on two gallons of denatured alcohol (which is of course is wood grain) and dumped in the tank. Second time it passed <img src="/forums/images/graemlins/cheers.gif" alt="" />
'89 Raider 3.0, auto
'73 ironhead sportster (compliments of my last Raider and a city of Aurora snow plow):)
Re: Does Seafoam lower emissions? [Re: Mike_Glenn] #897273 07/25/08 07:09 AM
RaideroftheLostArk Offline
What year Monty and engine are you running?
1991 Montero 3.0 V6 LSD, 31x10.50 BFG All Terrains
Re: Does Seafoam lower emissions? [Re: RaideroftheLostArk] #897274 07/25/08 11:21 AM
Y
yankneck696 Offline
It will surely help remove carbon deposits. Use a vacuum line from the throttlebody to run it in & then shut down. Restart it 1 hour later & suck some water or windshield washer thru it. It will smoke quite a bit on restart.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Does Seafoam lower emissions? [Re: RaideroftheLostArk] #897275 07/25/08 08:37 PM
yes, I have a '94 3.5 SR - 6G74 engine - sorry, I thought it was in my signature
Re: Does Seafoam lower emissions? [Re: yankneck696] #897276 07/25/08 08:40 PM
thanks - these are good tips. do you know if it reduced your HC for smog test?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6127 MB (Peak: 0.6903 MB) Data Comp: Off Server Time: 2026-06-21 01:27:16 UTC
