Stuck in 4WD #897443 07/25/08 07:28 PM
JAVYPRO Offline OP
Darn it!!! 4WD has always work flawlessly but last night I went to back up from a parking and heard a "CLICK, CLICK" and next thing tires are chirping Hmmmmm <img src="/forums/images/graemlins/confused.gif" alt="" />
Then 4x4lock light went off, so since then I am stuck on 4WD HI. <img src="/forums/images/graemlins/scared.gif" alt="" />
To tell you the truth the last time I repacked the front hubs was about 4 or 5 years ago when I did the V6 break conversion.
Will pulling all out and repacking the auto hubs fix the issue? or am I encountering other issues there?
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Stuck in 4WD [Re: JAVYPRO] #897444 07/25/08 09:22 PM
ES_97Sport Offline
Are you actually IN 4WD, or are the hubs/axle disconnect just 'locked'? I ask 'cause I had a similar problem when I first bought my Sport - the front axle stayed locked but 4WD wasn't actually engaged. Turned out it was a grounding problem. If it's actually IN 4WD and shifting out doesn't do it then it's unlikely repacking the hubs is going to do anything other than saving you from having to do that in the near future.
Re: Stuck in 4WD [Re: ES_97Sport] #897445 07/25/08 09:28 PM
JAVYPRO Offline OP
yup, it is shifted to 2WD but the hubs are locked. Waht do you mean by grounding problem? my problem is with my 1988 it is all mechanical there,if you are talking about electrical that is.
Javy
Re: Stuck in 4WD [Re: JAVYPRO] #897446 07/25/08 10:49 PM
You might try backing up while sawing the wheel back and forth and applying the brakes at times. It's worked for me on all but one Raider with auto hubs. Just a thought.
Re: Stuck in 4WD [Re: JohnnyBfromPeoria] #897447 07/26/08 12:02 AM
jeepdriver Offline
Javy I have a spare set of auto hubs compliments of MarkG you are welcome to if you need them.
Too many 4x4's, not enough time or money
Re: Stuck in 4WD [Re: jeepdriver] #897448 07/26/08 04:32 AM
torquemonster Offline
try going onto some grass or gravel or something and going in reverse fast...then slamming on the breaks to lock up the tires...that always worked on my old 88 d-50 when the hubs got stuck. it wouldn't even make a "bang" or "click" it would just free up as normal.
Re: Stuck in 4WD [Re: torquemonster] #897449 07/26/08 07:24 AM
Bhealy Offline
OR spend $100 for manual hubs <img src="/forums/images/graemlins/wink.gif" alt="" />
87' Raider: off road package, rebuilt engine with (new) stock tires and alloy wheels but otherwise original.
Re: Stuck in 4WD [Re: Bhealy] #897450 07/26/08 03:15 PM
JAVYPRO Offline OP
Bruce
thanks for the offer,Ill take your word on it.
The rest of the gang,
I will try all your suggestions, as we speak I am taking the whole thing appart to meka sure it is all up to spec and to ensure they are well lubed.
This is from my garage PC, so I will be posting as the progress goes on.
Now, it is time to get dirty. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Javy
Re: Stuck in 4WD [Re: JAVYPRO] #897451 07/26/08 03:25 PM
hazy_daze Offline
Javy, if you need help, I can come over this afternoon after work. It'd be about 3 before I can get there. My truck is going to be down for awhile. If you want to use my Superwinch hubs, I can bring them with me. Let me know, you gots my number.
Re: Stuck in 4WD [Re: hazy_daze] #897452 07/26/08 04:18 PM
JAVYPRO Offline OP
Larry,
Thanks, sorry now I see you called me. let me take this off and see waht I find. I will be out of here by 3:00pm since I got to go tose the boxing match today Miguel Cotto vs Antonio Margarito wooooo. Cotto is from Puerto Rico so i got to see the best pound per pound in the 147lbs of the world <img src="/forums/images/graemlins/kewl.gif" alt="" />
Well back to hubs, will the auto hub s eventually go bad? what is it a srping or something?
Javy
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6406 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-11-03 13:21:38 UTC
