Vacuum leaks in 94 3.5 SR #897461 07/25/08 09:38 PM
Mike_Glenn Offline OP
What have you experts out there found are common vacuum leaks on this model? I was told that one source of high hydrocarbons could be a vacuum leak, and I have that funky butterfly valve assy.
what hoses usually crack or leak?
thanks!
'94 Montero 3.5 SR, 202,000 mi.
Re: Vacuum leaks in 94 3.5 SR [Re: Mike_Glenn] #897462 07/25/08 10:30 PM
Bhealy Offline
I just bought a bulk role of black tubing in the same diameter and went at all of em... you may have a few in the wrong place too...
87' Raider: off road package, rebuilt engine with (new) stock tires and alloy wheels but otherwise original.
Re: Vacuum leaks in 94 3.5 SR [Re: Bhealy] #897463 07/26/08 01:31 AM
Unhook the butterfly electrics, wire the arm in place, and RTV the shafts at the manifold.
Re: Vacuum leaks in 94 3.5 SR [Re: fasteddy] #897464 07/26/08 07:05 AM
good idea - which way should I wire them - long path or short for best smog?
thanks!
Re: Vacuum leaks in 94 3.5 SR [Re: Mike_Glenn] #897465 07/26/08 07:18 PM
Shouldn't make a diff. It's just a tuning aid for hp. The off at rest position should be right for low rpms, and I don't think the smog test gets to rpms above the changeover threshold.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6055 MB (Peak: 0.6693 MB) Data Comp: Off Server Time: 2026-11-02 12:37:16 UTC
