Won't stay runnig!
#897621
07/27/08 03:01 AM
I have a 1991 4Runner that won't stay running. After I start it and and it idles down to 800 rpm it stalls out after about 30 seconds, and right before it stalls it acts like the battery is dead (gauges die, lights dim out), but when I check the battery after it stalls it reads between 11 and 12 volts. After it dies it will start up right away and do the same thing. What could be the problem? PLease help and thanx for any insight!!!
Re: Won't stay runnig!
[Re: JoCooL]
#897622
07/27/08 06:29 AM
Could be a loose connection somewhere between the alternator, battery and the rest of the truck. But I like to look for the easy/cheap fix first.
[Re: JoCooL]
#897623
07/27/08 09:19 AM
definitly check your connections first, but i wouldn't necessarily focus on strictly electrical. in the event that its not an electrical issue, you would still see an "electrical dieback" just before stalling because your "generator" has quit running.
has it always done this? if you keep your foot on the gas will it run? when was your last tuneup? has it sat for a while?
rolled it on a snowbank. now i'm not afraid to scratch it. liberation.
[Re: rolled]
#897624
07/27/08 04:52 PM
i wana say bad battery or alternator. but what engine in this?
[Re: rolled]
#897625
07/27/08 05:53 PM
Its a V6 It was on the road for a couple of weeks after sitting for a couple months. This is the first time this has happend. If I keep my foot on the gas it can stay running . I hope this helps you help me ! Thanx so much
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6032 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-11-04 19:54:29 UTCValid HTML 5 and Valid CSS
