body lift? or other? #898040 07/29/08 01:25 PM
RaiderRandy Offline OP
I need the quickest and least painlful way to bring my front end up at least 2" and probably more like 2.5" As you know I got another Raider and the last guy installed OME springs in the rear after I replaced the completely worn out rear shocks it raised it even more. If I crank up the torsion bars is it going to affect my alignment? Will I need to get it re-alinged? Would a body lift be better? I dont want to keep driving down the street looking like I'm stuck in the 70's with a '74 Camaro and a set of Highjacker shocks on the back! <img src="/forums/images/graemlins/smile.gif" alt="" />
'89 Raider 3.0, auto
'73 ironhead sportster (compliments of my last Raider and a city of Aurora snow plow):)
Re: body lift? or other? [Re: RaiderRandy] #898041 07/29/08 01:48 PM
sparkem Offline
If you only install a body lift, it will still sit nose down. To get just the front up, you will have to crank the torsion bars.
Re: body lift? or other? [Re: RaiderRandy] #898042 07/29/08 02:03 PM
Oyaji_Jon Offline
The quickest and least painful is to crawl under the truck and adjust those torsion bars to level out the truck. Keep in mind that if you crank on them until the bump stops make contact, the ride will be very rough and your shock absorbers will have no chance to affect your ride.
Now, what you DON'T want to do is put in half a body lift to level the body to the road. Bad stresses on the body = trouble down the road. Besides that, the body lift can be a bit troublesome...
Trim the bump stops and crank those bars. All will be good. Your rear shocks didn't lift the truck, by the way, they'll soften up a little after they cycle a few times. Good luck!
Edit: Dammit, it takes me forever to type. Sparkem said it already... <img src="/forums/images/graemlins/cheers.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: body lift? or other? [Re: RaiderRandy] #898043 07/29/08 04:46 PM
CapnCrunch Offline
From your previous thread on the subject of leveling out, swap out the UCAs then crank the t-bars. It's quicker, easier, AND cheaper than doing a body lift and will address the alignment issues (and others).
And as mentioned, a body lift won't address your specific issue.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: body lift? or other? [Re: CapnCrunch] #898044 07/29/08 05:05 PM
hazy_daze Offline
What about 35's in the front and 33's in the rear <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: body lift? or other? [Re: RaiderRandy] #898045 07/30/08 02:54 AM
Pics?
<img src="/forums/images/graemlins/lol.gif" alt="" />
Re: body lift? or other? [Re: cmonty72] #898046 07/30/08 03:02 AM
Thanks all, alright trim and crank it is. Although I like the 35" and 33" thing too <img src="/forums/images/graemlins/lol.gif" alt="" /> [img][image]http://i324.photobucket.com/albums/k334/raiderandy/silverraider002.jpg[/img][/image]
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6170 MB (Peak: 0.7121 MB) Data Comp: Off Server Time: 2026-06-17 10:46:41 UTC
