1991 Montero V6 will not start #898109 07/30/08 12:37 AM
dwehbie Offline OP
HELP My 1991 Montero V6 will not start. There is a spark from the coil wire but low or no spark at the plug wires. What should I look for?
1996 Toyota T100
Re: 1991 Montero V6 will not start [Re: dwehbie] #898110 07/30/08 01:29 AM
Check the inside of the cap for deposits on the electrodes...maybe too high resistance for the arc to jump.
Re: 1991 Montero V6 will not start [Re: rxinhed] #898111 07/30/08 01:54 AM
New cap, rotor, and plug wires, IF the coil spark is jumping at least 1/4" and is hot blue white.
Re: 1991 Montero V6 will not start [Re: fasteddy] #898112 07/30/08 03:29 AM
dwehbie Offline OP
I should have told you that my son had put the plug wires on wrong. Put them on correctly and it started. Just one more question. I notice that when I disconnect one of the plug wires from a plug when the engine is running, an arch jumps at the coil near where the coil wire goes to the distributor. Is the coil going bad?
1996 Toyota T100
Re: 1991 Montero V6 will not start [Re: dwehbie] #898113 07/30/08 11:06 AM
FrankR Offline
No, the coil is fine...... what's happening is the charge is taking the least resistive path to ground - in this case, the frame around the coil. Every Mitsubishi coil I've seen does it. One way to make sure your wires are installed with good connections is to raise the hood with the engine running when it's dark - and watch the coil - if it arcs, you have a bad wire connection somewhere.
Frank
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6053 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-06-10 07:17:03 UTC
