lower control arm
#898136
07/30/08 04:37 AM
I'm trying to get the CV shaft out to change the boots ('88 4x4 p.u.) but just can't get it to drop through the lower control arm. My local certified Toyota mechanic told me that at the dealer they drop the lower control arm. Sounds right to me but after disconnecting everything, including loosening the control arm bolts, sway bar bushing, and ball joint connections, it won't drop for anything! I've smacked it with a 4# hammer and broken a screw-in puller arm trying to push the ball joint shaft through. Is this thing just rusted fast or have I missed something? Any ideas on how to get the control arm to drop? Thanks!!
Hook 'Em
Re: lower control arm
[Re: Bevoman]
#898137
07/30/08 05:21 AM
Look at this post here Removing drive axle
[Re: Snowtoy]
#898138
07/30/08 06:05 AM
This is how my neighbor showed me how to do it. He is the Foreman at Roseville Toyota. This shows me doing it on a TRE but I have also used it on balljoints. Take the cotter key and nut off. ![[Linked Image]](http://pics.montypics.com/oops/2008-07-29/1217394076_tre_removeal.jpg)
"Serenity through Sobriety"
[Re: OOP'S]
#898139
07/30/08 08:49 PM
oops, I think he's talking about getting the front half shaft out by droping the lower A-arm. I'll keep that in mind when I have to replace the it in the field. I think I used a ideler arm puller when I did my SAS.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
[Re: anthony1]
#898140
08/02/08 12:05 AM
J Roll Me Over
Don't drop the a-arm... Pound the studs out of the stub shafts, grind the splines off of them before re-installation.
With the studs out, the half-shafts will fall right out. <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: DRTDEVL]
#898141
08/02/08 04:59 AM
With the studs out, the half-shafts will fall right out. <img src="/forums/images/graemlins/wink.gif" alt="" /> Eh, screw all that grinding. Just but some Grade 8 bolts and locknuts.
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
[Re: DRTDEVL]
#898142
08/02/08 09:14 PM
oops, I think he's talking about getting the front half shaft out by droping the lower A-arm. I'll keep that in mind when I have to replace the it in the field. I think I used a ideler arm puller when I did my SAS. I know that but he said he broke a puller trying to get the BJ out. I've smacked it with a 4# hammer and broken a screw-in puller arm trying to push the ball joint shaft through.
