swap 3.0 L v6 for 4m40 #898631 08/02/08 11:51 PM
G
gsitts Offline OP
I need a new engine for my 1990 3.0L v6 montero and saw an ad for a JDM 4m40 pajero turbo diesel with 5 spd transfer case etc. or one with an auto and transfer case and I'm thinking about the conversion... Has anyone done this? Has the 4m40 got a good reputation? Does the 4m40 require an ecu or does it have mechanical injection? Is the auto trans
computer controlled ? Any thoughts or insights would help helpful.
Thanks Gordon
Re: swap 3.0 L v6 for 4m40 [Re: gsitts] #898632 08/04/08 10:44 PM
Bernoulli Offline
For what it's worth, the local MMC dealer says the 4M40 is more reliable than the 4D56 - timing chain instead of belt. It seems to be a bit more powerful and use the same or less fuel. You can check http://www2.pajeroclub.com.au/forum/ and http://www.pocuk.com/forums/index.php for more info. My experience is that operating costs are similar. Diesels, generally speaking, are 20% more fuel efficient (In OZ they keep the cost of diesel 20% higher). The cost of everything on a diesel is higher - parts, filters etc. 4M40 parts will be hard to find in the U.S.
All that being said, I'd like to try the same thing, but with a manual transmission.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: swap 3.0 L v6 for 4m40 [Re: gsitts] #898633 08/06/08 02:26 AM
Glock24 Offline
As far as I know, the 4D56 is a direct swap from the 3L V6, but don't think the 4M40 is, as the transmissions, engine mounts, etc. are different.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5965 MB (Peak: 0.6505 MB) Data Comp: Off Server Time: 2026-05-26 03:47:39 UTC
