Clarification, Front Hub Rebuild #898667 08/03/08 02:57 PM
Richards19884x4 Offline OP
Not knowing what condition my hubs are in on my recently purchased 4x4, I think I want to rebuild them. Everything else on the truck seems to have been ignored or screwed by the PO, so why not (239K miles). I have read several articles and threads here, but I am confused about the references to the 54MM locknut socket. My truck is a mostly stock 1988 with manual Aisin hubs and IFS front end. I don't see anything in my FSM that would lead me to believe this big socket is needed except possibly on the automatic hubs, which I don't have. Before I start tearing stuff apart, can anyone tell me for sure what I need to have on hand to be prepared for this venture? The truck is my DD, so preparation is key. Any insight specific to an 88 truck would be appreciated.
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: Clarification, Front Hub Rebuild [Re: Richards19884x4] #898668 08/03/08 03:45 PM
P
philly Offline
you can just take your hubs off wiht a 12mm 10mm and a hammer, no 54mm is needed unless you were doing wheel bearings. when i rebuilt my hubs i just drove around with nothing for a day.
Re: Clarification, Front Hub Rebuild [Re: philly] #898669 08/03/08 04:06 PM
OOP'S Offline
If you are servicing the wheel bearings, you need the 54mm socket. The axle hub & disc goes on, then the outer wheel bearing, then a keyed washer, 54mm adjusting nut, keyed locking washer, 54mm lock nut, hub body, hub cover.
If you are just servicing the locking hubs, you do not need it.
I would recommded servicing the wheel bearings if you do not know when they were serviced last for that you will need to get the inner hub seal.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clarification, Front Hub Rebuild [Re: philly] #898670 08/03/08 05:07 PM
... when i rebuilt my hubs i just drove around with nothing for a day.
Must be a yankee thing. Around here, you get arrested for driving around with nothing. <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
Richard S.
Re: Clarification, Front Hub Rebuild [Re: OOP'S] #898671 08/03/08 05:09 PM
I want to either repack or replace the bearings. I will purchase the 54mm. I saw one at summit racing. Anybody else know a good source?
Richard S.
Re: Clarification, Front Hub Rebuild [Re: Richards19884x4] #898672 08/03/08 06:16 PM
OOP'S Offline
I got mine at Sears, it is not metric it is a 2 1/8 inch.
David Fritzsche
Roseville, CA
Re: Clarification, Front Hub Rebuild [Re: OOP'S] #898673 08/03/08 09:03 PM
Just a deep 2 1/8"? Does it have to be a 6-point? Hard to tell from the pics online, but I didn't know if I bought a 2 1/8" if it would be deep enough to clear the end of the axle and reach the nut (I am assuming the nut is behind the mechanical locking hub part).
Richard S.
Re: Clarification, Front Hub Rebuild [Re: Richards19884x4] #898674 08/03/08 09:35 PM
OOP'S Offline
The one I got is a regular socket, 12-point, works fine. It is 3/4 drive so I had to get an adapter to 1/2 inch that I got at Harbor Freight for a couple of dollars. Marlin, Trail Gear and I think All-Pro also sell them. They are the stamped steel kind where as the Sears one is a regular socket.
David Fritzsche
Roseville, CA
Re: Clarification, Front Hub Rebuild [Re: OOP'S] #898675 08/03/08 11:39 PM
Thanks for the info and help. I already have a 3/4 adaptor, so maybe a trip to Sears is in order. Thanks to everybody who pitched in. <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Richard S.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6277 MB (Peak: 0.7311 MB) Data Comp: Off Server Time: 2026-07-14 10:41:43 UTC
