Is it rod knock?? #898696 08/03/08 08:22 PM
Witsubishi Offline OP
Russ put a battery in the new Montero, fired it up and a horrible noise started occurring. There was good oil pressure and the noise was louder when revved up. It went "bang, bang, bang"... <img src="/forums/images/graemlins/evil.gif" alt="" />
He finally bought me a running Montero, but it still needs work. What are your thoughts?
Bonnie - 1989 Montero LS 4-door, black, loaded, sunroof, dual bouncies, 31" BFGs
Clyde - 1989 Montero LS 4-door, black, loaded, alloys, stock
Re: Is it rod knock?? [Re: Witsubishi] #898697 08/06/08 06:02 AM
V
vr4 Offline
sounds like rod knock.
when i spun a bearing in my old stealth oil pressure was normal.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Is it rod knock?? [Re: Witsubishi] #898698 08/06/08 06:17 AM
87Montero Offline
chitty chitty bang bang???
Just kidding, its probably rod knock.. but the good news is that with all those monteros.. its not all that difficult to make one engine out of two if one's got bad electronics, and has a good bottom half, etc.. or am I thinking like myself again?
Re: Is it rod knock?? [Re: 87Montero] #898699 08/08/08 05:20 AM
OK, advise:
I have the 91 LS that dT really wants the oil pan from, so I have to pull the engine anyway. How durable are the 3L short blocks when run with no water for about 10 miles?
The PO was this looooooooopy hippy chick who let her 17 year old son kick the Montero for overheating. They had to have cigarettes, so they drove the Monty. <img src="/forums/images/graemlins/drunk.gif" alt="" />
How about just changing the con rod bearing? Stifle your laughs, I did this on my 68 Buick and drove for another month before the license expired.... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Witsubishi's in-house mechanic.
Re: Is it rod knock?? [Re: rxinhed] #898700 08/08/08 05:26 AM
87Montero Offline
Provided the crankshaft was not damaged and within spec.. you shouldn't have any problems replacing the bearings and going along.. but think about all the metal shavings that have traversed through the engine, oil pump etc.. <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Is it rod knock?? [Re: 87Montero] #898701 08/08/08 05:49 AM
Yah, I said about my Buick, but it was wasted...used 60 wt racing oil, 1.5 qts every 200 miles...loosey goosey.
I'm going to have to evaluate the 91 engine, everything V6 here has about the same 225K miles on it. <img src="/forums/images/graemlins/frown.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6154 MB (Peak: 0.6860 MB) Data Comp: Off Server Time: 2026-10-24 13:10:48 UTC
