Diesel engine battles to start when cold #898747 08/04/08 10:07 AM
I
isuzu101 Offline OP
Hi. My isuzu 280 DT really battles to idle in the mornings. It starts then idles extremely rough with a lot of white smoke. The engine will then start to die and no matter how much fuel i give it, it will continue to die.Start again and keep the peddle down and revs above 1500rpm and i have to warm it up like this for at least 5 minutes!
Strangley once the engine is warm and going the vehicle pulls well, there is absolutely NO smoke even flat foot on the uphill and it starts and idles fine once warm.
Whats been done: ive replaced glowplugs( they are heating-tested)
- fitted a new fuel line (no air in system).
Any advise? The injectors were also supposedly done.
Re: Diesel engine battles to start when cold [Re: isuzu101] #898748 08/07/08 05:06 PM
RobG Offline
does the ambient temp have any effect on this? how cold does it get where you're at? or is it just the fact its a cold start?
-Rob
Re: Diesel engine battles to start when cold [Re: isuzu101] #898749 08/07/08 08:20 PM
Matski Offline
Are the plugs drawing amps? Can't think it can be much else?
White smoke is unburned diesel...
1989 3.1 Isuzu Bighorn Hybrid
2" Lift with longer shocks
31.10.50R15 Recip Trials
Full 2.5" free flow stainless system
Front mount intercooler
Pump tuned
4.56 Diffs
Re: Diesel engine battles to start when cold [Re: Matski] #898750 08/12/08 08:40 AM
I
isuzu101 Offline OP
It gets to maybe 10 degrees celcius at the moment on a cold night. yes the plugs are drawing current. the only possibility i can think of is there is something with the pump setting as i have no idea how the pump opperates. someone mention that the pump might have a cold start solenoid on it or something to that extent.
Re: Diesel engine battles to start when cold [Re: isuzu101] #898751 08/17/08 08:43 PM
Matski Offline
Sorry for late reply.
Is it the 2.8 diesel 4JB1? if so it has a cold start solenoid on the back of the fuel pump. There are two one is the stop solenoid and one is the cold start.
The cold start leaves the glows on longer (after the light goes off) and ups the idle slightly.
I run a wire from the batery to the glows via a starter solinoid and don't have the cold start system working at all and it starts fine.
http://www.itocuk.co.uk/forums/viewtopic.php?t=11721&highlight=mini
Pump tuned
4.56 Diffs
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6052 MB (Peak: 0.6700 MB) Data Comp: Off Server Time: 2026-07-16 21:14:28 UTC
