Has to cool before starting
#898882
08/05/08 12:21 AM
1996 Tacoma 4x4 Manual 5 speed 4 cylinder 265,000 miles. If I drive around a while then turn my truck off and it won't start for about 20 minutes or so until something cools off. Runs fine after it starts. I replaced the ignition coil hoping that would take care of the problem but no luck. The summertime temperature here in Albuquerque gets pretty hot but I have not had this problem until recently. Battery, alternator, etc is okay. Starts right up after 20 minutes or so. Any help would be appreciated.
2008 Tacoma 4x4 6spd manual SR5 TRD
Re: Has to cool before starting
[Re: hairytaco]
#898883
08/06/08 05:32 PM
Does the starter seem to drag or turn the motor over slow when it acts up? Or does it turn the motor over normaly but not start?
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
[Re: john_luttrell]
#898884
08/06/08 08:40 PM
The motor turns over normally like it is going to start but just will not start. I wait a while (about 20 minutes) and it starts like there was never a problem. I had the same problem with a Chevy truck I used to own and replacing the electronic ignition coil module fixed it right up....no such luck in my Toyota.
[Re: hairytaco]
#898885
08/06/08 09:45 PM
Could possibly be a problem with the ECU temp sender.
[Re: hairytaco]
#898886
08/08/08 08:44 AM
There was a guy over on ToyotaNation.com who had a similar hot start problem.
Well, I got the problem solved FINALLY!! What was happening, was that the fuel injectors were leaking fuel into the cylinders and flooding the engine on a hot start. When enough time passed that the fuel dissipated, then the problem went away. I changed all of the injectors and now I do not have the problem any more...
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6069 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-10-24 02:37:16 UTCValid HTML 5 and Valid CSS
