so i found these springs...... #898985 08/05/08 11:51 PM
wyodriver4 Offline OP
so i was scrounging around my local junk yard, and i see a set of brand new coil springs sitting there, and im thinkin, those kinda look like i could run em under the kia for a little more lift. so i throw em in my pile of potential. the tag on them says the part number is 68004459aa and i cant find anything about them on the net. can anyone enlighten me?
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: so i found these springs...... [Re: wyodriver4] #898986 08/06/08 01:03 AM
DennisThompson Offline
You would have to know the make of vehicle they came off of to find what they are.
Dennis
Re: so i found these springs...... [Re: DennisThompson] #898987 08/06/08 01:40 AM
Iron Offline
459aa are springs from a Jeep XJ Grand Cherokee, fronts I believe as the xj has leafs in the rear!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: so i found these springs...... [Re: Iron] #898988 08/06/08 06:02 AM
Hydra747 Offline
The fronts will work if the struts operate properly (common sense)......
What are the specs???
We are rolling the dice without more info......
Re: so i found these springs...... [Re: wyodriver4] #898989 08/06/08 04:04 PM
Everet Offline
What is their length and diameter? Post a picture of them. Please measure their spring rate too.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6082 MB (Peak: 0.6723 MB) Data Comp: Off Server Time: 2026-10-22 12:13:29 UTC
