Re: Master Cylinder Wiring Connector Question [Re: matts] #899008 08/12/08 12:32 PM
P
philly Offline
i didnt test it for continuity. pretty much just spliced in the 2 wires. filled it with fluid and hoped my light would go off..
its in my wire box, i'm gona dig around for it today when i get out of work. i'll pm you later matt
Re: Master Cylinder Wiring Connector Question [Re: philly] #899009 08/12/08 02:08 PM
matts Offline OP
On second thought, a failure of continuity would probably result in no light. I think the circuit lights the idiot light by closing to ground. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Master Cylinder Wiring Connector Question [Re: matts] #899010 08/24/08 12:11 AM
CJM Offline
found the # if your interested ...
90980-11207
83 Trekker SR5
NEW Trekker forum
Re: Master Cylinder Wiring Connector Question [Re: CJM] #899011 08/25/08 12:44 AM
Redboar Offline
I got my Mcyl from Marlin and they did not have a source for the plug. I just went to pick a part and got it off of a later model that uses that style of plug. Was off of a
T100 if I remember correctly, but should work with other ones
also. Haven't had any trouble with the light coming on. <img src="/forums/images/graemlins/smile.gif" alt="" />
85 SR5 4X4 XTRA, 22RE
W56, Marlin Crawler 4.7
4" lift, 4.88
Re: Master Cylinder Wiring Connector Question [Re: Redboar] #899012 08/25/08 05:57 AM
matts Offline OP
I'd be in hog heaven if there was a pick-a-part around here. I'll try the number CJM came up with at the Toyota dealer. Thanks. -- Matt
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6129 MB (Peak: 0.6937 MB) Data Comp: Off Server Time: 2026-11-03 12:28:37 UTC
