LIFT HELP #899156 08/07/08 02:45 AM
mowermechanic Offline OP
I don't have the $900+ for the calmini 3" lift kit... nor do i have the $350+ for the upper control arms. In short, i want to torque up the front end so that i am still 1/4 - 1/2 inch away from the lower bump stops on the front end. But then my camber will be off. Couldn't i cut my upper control arms to the proper length and weld them back together a little shorter (with reinforcements of coarse) and i will lengthen the shackles in the back to match the lift in the front?!?
also, with the said combination, will 33x12.50 then fit? p.s. how do you insert a photo?
-Theo
Re: LIFT HELP [Re: mowermechanic] #899157 08/07/08 11:33 AM
strawmyers Offline
Isuzu Moderator
Just do a ball joint flip and possibly spacer (if needed) after cranking the t-bars. That should allow you to get the alignment within specs. Lots-o-info around here on the process. As for the photo, check the FAQ:
http://www.4x4wire.com/forums/faq.php?Cat=#image
Sean Strawmyer
Re: LIFT HELP [Re: mowermechanic] #899158 08/07/08 04:13 PM
BigSwede Offline
As to whether the tires will fit...which vehicle are we talking about? Those will definitely fit a Trooper...but other models have less clearance.
Photos have to be hosted on another website such as Photobucket, and linked here.
Serenity now!
Re: LIFT HELP [Re: mowermechanic] #899159 08/08/08 03:50 AM
Gizzy42 Offline
Need to know year and model to give the right advice.
Cant do ball joint flip on 2nd gen rodeo for example, but then it isnt needed either.
The independent4x lift has everything needed for alot less then the calmini kit.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: LIFT HELP [Re: Gizzy42] #899160 08/08/08 04:55 AM
it's an 1987 isuzu trooper, if i flip the ball joints, is it just the upper control arms? [image]<a http://s516.photobucket.com/albums/u323/mowermechanic/?action=view&current=trooper1.jpg
-Theo
Re: LIFT HELP [Re: mowermechanic] #899161 08/08/08 03:32 PM
lttlbddy Offline
Yes, just the upper. If you use a spacer it would go between the a-arm and the ball joint with the ball joint is under the a-arm.
Re: LIFT HELP [Re: lttlbddy] #899162 08/09/08 01:27 AM
what size spacer if i'm going to have the control arms almost touching the bump stops? also, where is a good place to buy such spacer? or a good template to make my own?
-Theo
Re: LIFT HELP [Re: mowermechanic] #899163 08/09/08 03:42 AM
lttlbddy Offline
The only game in town:
1/4" spacers
Re: LIFT HELP [Re: mowermechanic] #899164 08/09/08 04:26 PM
pucci Offline
if you don't mind running 9.5 or 10.5 tires instead of 12.5 you don't need a lift on 87-91 Troopers for 33" tires.
2.6 Trooper
2.0 Impulse Turbo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6259 MB (Peak: 0.7294 MB) Data Comp: Off Server Time: 2026-06-09 10:14:48 UTC
