3RZ-FE 2.7L exhaust questions... #899371 08/08/08 06:40 PM
riverrat Offline OP
Hi All,
Recently purchased a 2000 4runner with the 3RZ-FE 2.7L engine to replace my 1988 4runner.
On my 1988 4runner (22RE), at the suggestion of engnbldr, I put on a 2" pipe between the cat and muffler, then 2 1/4" pipe out of the muffler. This produced a quite noticeable increase in throttle response and power at WOT.
since 3RZ 4runners are so rare, I'd like to hear what owners of 3RZ Tacos are using for an aftermarket exhaust system, including aftermarket headers or just freer flowing exhaust pipes and mufflers- what size pipe(s) did you go with? And which muffler? I realize that there are tradeoffs between noise level and restriction, but I'd like to keep my new system as quiet as possible.
Any feedback will be appreciated!
Re: 3RZ-FE 2.7L exhaust questions... [Re: riverrat] #899372 08/10/08 08:24 PM
riverrat Offline OP
riverrat, according to engnbldr, you should go with 2" from the cat to the muffler, then 2 1/4" after the muffler just as with the 22RE, since these motors are of similar displacement.
Re: 3RZ-FE 2.7L exhaust questions... [Re: riverrat] #899373 08/10/08 08:24 PM
riverrat Offline OP
OK thanks!
Re: 3RZ-FE 2.7L exhaust questions... [Re: riverrat] #899374 08/11/08 02:54 AM
BIGBURLYNAKEDMAN Offline
WTF???
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: 3RZ-FE 2.7L exhaust questions... [Re: BIGBURLYNAKEDMAN] #899375 08/11/08 03:35 PM
Mark in AZ Offline
Toyota Moderator
What, he's populating the forum all by himself <img src="/forums/images/graemlins/smile.gif" alt="" />
Exploring in a T4R Ltd V8
Re: 3RZ-FE 2.7L exhaust questions... [Re: Mark in AZ] #899376 08/11/08 06:24 PM
riverrat Offline OP
Just having a little fun with info that came to light via an email communication with engnbldr after I had posed the question here and got no responses...
Re: 3RZ-FE 2.7L exhaust questions... [Re: riverrat] #899377 08/12/08 07:11 PM
Haha well thank you. At least if anyone's searching in here with your same question, they'll get a good answer!
Re: 3RZ-FE 2.7L exhaust questions... [Re: BIGBURLYNAKEDMAN] #899378 08/12/08 11:33 PM
G
Greg_Canada Offline
Lots of 3rz people over on customtacos.com... thorley came out with a new header for them which gives a nice 10-15hp dyno proven. i'd run a 2.25" exhaust with that for best flow...
89 4Runner
Re: 3RZ-FE 2.7L exhaust questions... [Re: Greg_Canada] #899379 08/21/08 04:06 PM
riverrat Offline OP
Yes I've been lurking over on the CT site. Do you know if the Thorley will definitely fit on a 3RZ 4runner? From what I have learned, some 3RZ headers fit Tacos but not 4runners, e.g. the one made by NW Offroad, which is the only tri-y design I have found.
Also, where can I buy a Thorley and/or get some tech questions answered?
Re: 3RZ-FE 2.7L exhaust questions... [Re: riverrat] #899380 08/23/08 10:25 PM
G
Greg_Canada Offline
89 4Runner
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6337 MB (Peak: 0.7564 MB) Data Comp: Off Server Time: 2026-10-24 05:38:14 UTC
