02 sensor madness... #899565 08/08/08 11:50 PM
93xtra Offline OP
sorry to throw in a question about my 4cyl, '03 Camry but I was confident someone might know the answer. My engine light came on and the computer read: "P0031, H02s, Bank 1 Sensor 1, Heater Circuit Low."
So I replaced the upstream sensor and the check engine light is still there even after disconnecting battery, then I tried clearing it using the diagnostic computer. Any ideas?
Thanks in advance!
Re: 02 sensor madness... [Re: 93xtra] #899566 08/09/08 02:00 AM
Richards19884x4 Offline
I'm just guessing here, but I think your heater circuit is low. Have you tried refilling it? <img src="/forums/images/graemlins/notooth.gif" alt="" /> (Sorry, can't help you unless it hooks up with a transfer case and 33's.)
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: 02 sensor madness... [Re: 93xtra] #899567 08/09/08 02:08 AM
This forum here has just Camry owners. Lots of discussions about codes for some reason...
Richard S.
Re: 02 sensor madness... [Re: Richards19884x4] #899568 08/09/08 02:19 AM
4Crawler Offline
Might want to check the O2 sensor connector and wiring. Common problem, at least on the pickups/4Runners is for the O2 wiring to fall against the hot exhaust and that melts the wiring insulation and can cause a short circuit.
Re: 02 sensor madness... [Re: 4Crawler] #899569 08/09/08 11:58 AM
93xtra Offline OP
Thanks for your replies! I had not found that Camry Forum and will with that... my truck never has problems for me to ask about!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6058 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-07-16 03:41:38 UTC
