Help question #899576 08/09/08 12:36 AM
A
Alloush Offline OP
Hey everyone. So I put on my spacer lift about a year ago and just now started trouble. Whenever im driving and hit a bump or drive in a high gear at low RPM's, my rig starts shaking like crazy!! I mean scary shaking. I tried droping my transfer case. that helped with some vibes with the shift knob, but didn't solve the problem at all. Went to a local 4X4 store and they said it was my Track bar. That one of the connections gets loose after a lift. Anyone want to comment? Is he right or could it be something else? Has anyone had a similar problem? Can I do the repair myself? Any help would be great. <img src="/forums/images/graemlins/confused.gif" alt="" />
05 TJ 2.25 BB. Skyjacker hydro 7000 shocks.
Re: Help question [Re: Alloush] #899577 08/09/08 03:15 AM
Bigbird79 Offline
Well it definitely sounds like something is loose or worn out. Does the vibration follow vehicle speed or engine speed? If it follows vehicle speed I would suspect something in the suspension or steering. If it follows the engine speed I would suspect something in the drive train.
I would crawl under it while having a buddy turn the wheel back and forth, and move all the suspension and look for any play in anything, (bushings, tie rod ends, loose bolts, a broken spring, etc.) if I suspected something in the suspension.
I would check each u-joint, and make sure all the lug nuts are tight, and if they were all good I would put the rig up on 4 jack stands and put it in gear, let it idle and see if anything was moving or vibrating that shouldnÆt.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: Help question [Re: Bigbird79] #899578 08/09/08 04:49 AM
Mudlover27 Offline
check the bolt (Frame side) of the rear pan hard bar (ie trac bar) if you put a drop bracket (most likely came with the lift kit) some time the bolt strips in the drop bracket making the bracket move ie makes the rear end jump around, if a an offroad shop looked at it I would start there as well as follow the other posts advice
98 wrangler 2.5l 3 inch rustys, 2 inch body, 33X12.5 MTR's DETROIT LOCKER, 4.88 gears, moser axles, Dana 44 (rubicon housing)
Re: Help question [Re: Mudlover27] #899579 08/16/08 05:51 AM
E
el_d_m Offline
did you put on different tires? were they used? mi had a death wobble caused by out of round tread. rotate your tires & see what happens.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6007 MB (Peak: 0.6569 MB) Data Comp: Off Server Time: 2026-06-07 03:12:28 UTC
