Replacement Fender Panels
#899608
08/09/08 03:35 AM
Does anyone know where I can get replacement rear fender panels?
ttreat 95 T-100 SR5 4x4 Pretty much stock, except for the goofy oil pressure gauge the previous owner installed.
Re: Replacement Fender Panels
[Re: ttreat]
#899609
08/09/08 03:59 AM
[Re: ttreat]
#899610
08/09/08 04:00 AM
as far as i know the bedis all 1 pc as its welded together. You would need another bed and need to do some cutting and welding.
[Re: ttreat]
#899611
08/09/08 12:03 PM
Dealer. For my X cab (short bed) they list $462 wholesale $333 each. Ask for PNC 65816A and 65817A.
There are a number of different panels that are welded together, toyota's body manual only seems to discuss the cab body, not the bed, so I dont know where to look for cut/weld instructions.
You can also get the whole side of the bed with inner wall, wheel arch, reinforcements and both ends already welded together That is $1200. Whole bed (with tailgate) $4600.
The floor, front wall, and mounting brackets can also be had by themselves.
97 T100 4x4 97 328i 95 540i restoration project
[Re: eleet]
#899612
08/09/08 08:46 PM
I just wanted skins. I can cut and weld them in. If necessary I will make them with sheet metal but I would prefer a precut panel that I could install.
$333 a peice is robbery. You could buy a whole new replacement fender for a car for less than $100. Are there any aftermarket manufancturers?
[Re: ttreat]
#899613
08/10/08 02:43 AM
Let us know what you find - there weren't many of these made, so it would be interesting to know this metal is available on the aftermarket.
Toyota has a racket going on in the parts dept. Anytime a quality replacement turns up we need to know about it. And we need to know about the off brand parts that are crap as well.
[Re: eleet]
#899614
08/10/08 05:27 AM
you can get fiberglass from a few companies in Socal. but it would look a little funny with stock fronts since they're flaired.
