Replacement Fender Panels #899608 08/09/08 03:35 AM
ttreat Offline OP
Does anyone know where I can get replacement rear fender panels?
ttreat
95 T-100 SR5 4x4
Pretty much stock, except for the goofy oil pressure gauge the previous owner installed.
Re: Replacement Fender Panels [Re: ttreat] #899609 08/09/08 03:59 AM
Jake97T Offline
you just want the skins?
Re: Replacement Fender Panels [Re: ttreat] #899610 08/09/08 04:00 AM
CJMT100 Offline
as far as i know the bedis all 1 pc as its welded together. You would need another bed and need to do some cutting and welding.
Re: Replacement Fender Panels [Re: ttreat] #899611 08/09/08 12:03 PM
E
eleet Offline
Dealer. For my X cab (short bed) they list $462 wholesale $333 each. Ask for PNC 65816A and 65817A.
There are a number of different panels that are welded together, toyota's body manual only seems to discuss the cab body, not the bed, so I dont know where to look for cut/weld instructions.
You can also get the whole side of the bed with inner wall, wheel arch, reinforcements and both ends already welded together That is $1200. Whole bed (with tailgate) $4600.
The floor, front wall, and mounting brackets can also be had by themselves.
97 T100 4x4
97 328i
95 540i restoration project
Re: Replacement Fender Panels [Re: eleet] #899612 08/09/08 08:46 PM
ttreat Offline OP
I just wanted skins. I can cut and weld them in. If necessary I will make them with sheet metal but I would prefer a precut panel that I could install.
$333 a peice is robbery. You could buy a whole new replacement fender for a car for less than $100. Are there any aftermarket manufancturers?
ttreat
95 T-100 SR5 4x4
Re: Replacement Fender Panels [Re: ttreat] #899613 08/10/08 02:43 AM
E
eleet Offline
Let us know what you find - there weren't many of these made, so it would be interesting to know this metal is available on the aftermarket.
Toyota has a racket going on in the parts dept. Anytime a quality replacement turns up we need to know about it. And we need to know about the off brand parts that are crap as well.
97 T100 4x4
97 328i
Re: Replacement Fender Panels [Re: eleet] #899614 08/10/08 05:27 AM
Jake97T Offline
you can get fiberglass from a few companies in Socal. but it would look a little funny with stock fronts since they're flaired.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6150 MB (Peak: 0.6927 MB) Data Comp: Off Server Time: 2026-06-17 11:42:20 UTC
