Page 1 of 3 1 2 3
100 octane at the pump ;o) #899662 08/09/08 09:30 PM
Coyotekid Offline OP
Brand new gas-station put in down the street.. and I about had to change My underware when I saw this:
Only $7.79 a gallon though <img src="/forums/images/graemlins/scared.gif" alt="" />
LOL
Almost tempted to fill up once with it.. see if there is ANY kind of difference at all lol
-Dano-
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 100 octane at the pump ;o) [Re: Coyotekid] #899663 08/09/08 09:43 PM
52degrees Offline
You should notice an increase in performance what with the lightening of your wallet.
Last time I saw a racing fuel pump it was $3.99 a gallon. Now regular cost that.
KG6VNX
Re: 100 octane at the pump ;o) [Re: Coyotekid] #899664 08/09/08 09:45 PM
LRJ4x4 Offline
High octane gas does not increase performance in low compression engines. It's a waste of money unless your driving a race car <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 100 octane at the pump ;o) [Re: LRJ4x4] #899665 08/09/08 09:48 PM
LRJ4x4 Offline
I forgot to add you have been brainwashed by big oil. It's just free money for them.
Here is my proof
http://www.state.mn.us/mn/externalDocs/Commerce/Gasoline_Octane_Facts_102902052227_OctaneFacts.pdf
Re: 100 octane at the pump ;o) [Re: LRJ4x4] #899666 08/09/08 09:49 PM
52degrees Offline
I wasn't claiming that the fuel would add performance. I was sayinjg that his car would perform better without all the excess weight of the cash he carried in his wallet.
KG6VNX
Re: 100 octane at the pump ;o) [Re: LRJ4x4] #899667 08/09/08 10:13 PM
Kevin C Offline
Here is my proof
There are at least two major errors in that FAQ. Nothing worse that a FAQ furthering myths.
Anyone else notice?
Kevin
Re: 100 octane at the pump ;o) [Re: Kevin C] #899668 08/09/08 10:52 PM
52degrees Offline
I couldn't be bothered to look. BRB.
KG6VNX
Re: 100 octane at the pump ;o) [Re: 52degrees] #899669 08/09/08 10:54 PM
52degrees Offline
Ok. I saw them. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
KG6VNX
Re: 100 octane at the pump ;o) [Re: Kevin C] #899670 08/09/08 11:18 PM
FrankR Offline
I don't think that cylinder pressures are necessarily higher at full throttle. That would be dependant on ignition timing and fuel octane rating.
Frank
Re: 100 octane at the pump ;o) [Re: 52degrees] #899671 08/09/08 11:24 PM
LRJ4x4 Offline
Wasn't knocking you ( pun intended ) saw the wallet part <img src="/forums/images/graemlins/lol.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6410 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-10-22 07:36:08 UTC
