gen I dome light (again) #899971 08/11/08 03:28 PM
builthatch Offline OP
i've searched on here about these things not working well, and i've seen the rivets blamed, and the door switches blamed.
when i got my montero, the light didn't work. someone had already squeezed the rivets, and the door switches work. when i multimeter the terminals going to the dome light selector switch, there is power where it should be. the only thing that is left then is the actual ceiling switch. i took apart the switch, you know, it has a detent ball and spring that provides the contact between the different points. well, i cleaned the ball, and cleaned the contacts with rc motor spray, and it worked.....for about 3 hours. man does that bulb burn hot!!!
it still gets power to the terminals going to the switch, just like before, but no workey.
what gives with this thing? is there a known problem with the material used for the detent ball and the contacts it hits?
'87 swb 5spd 2.6L Montero, >150k miles. Pretty much bone stock as purchased from user ToddStidham1, 'cept some Hella 500's, 700's and Hella ECE headlight conversions.
6'4", 315lbs
Re: gen I dome light (again) [Re: builthatch] #899972 08/11/08 04:15 PM
Tag Offline
I dont know but if you want to replace it newer Ford escorts look like the have the same light.
Mine works fine. All I have done is change the bulb several years ago.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: gen I dome light (again) [Re: Tag] #899973 08/11/08 05:26 PM
jdchappell Offline
some guys here on the forum have purchased the LED type lights from ebay and they say it works better and doesnt get hot.
Re: gen I dome light (again) [Re: jdchappell] #899974 08/11/08 05:36 PM
yeah, i def would be interested in that. seems like people have really liked that upgrade, but i have to first figure out why the dome light switch is so finicky!
6'4", 315lbs
Re: gen I dome light (again) [Re: builthatch] #899975 08/11/08 08:38 PM
I've put a Balkamp truck interior light in. It uses an 1156 bulb...talk about HOT and bright!
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6091 MB (Peak: 0.6744 MB) Data Comp: Off Server Time: 2026-11-03 04:54:17 UTC
