Page 1 of 3 1 2 3
High idle and I'm thinking throttle body #900055 08/12/08 04:45 AM
DirtDriver Offline OP
A month or so ago, I noticed my idle was starting to waver and was on the high side, maybe 1400 cold or warm. Put a new ISC on order from DMCISC. While waiting, I cleaned the throttle body with a spray throttle body cleaner (after plugging the TB ports). Other than a helava lot cleaner, didn't notice much of difference, maybe idling a little higher. Installed the new ISC. Waver gone, and for awhile the idle lowered to maybe 1200. A few days later, the idle is 1800-2000 no difference cold or warm. Like that for a week. Replaced the engine coolant temp sensor Saturday. No difference.
I don't think I have a vacuum leak, as my vacuum gauge (tee'd off one of the plenum hoses) is a normal, solid 15psi when idling.
Today it was 1800 when starting and 1800 arriving at work 20 minutes later, and 1800 leaving work but down to 1200 arriving home 20 minutes later. Probably an anomaly.
I'm thinking the fast idle air valve in the throttle body is stuck open and the ISC isn't able to compensate.
Time to replace the TB?
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: High idle and I'm thinking throttle body [Re: DirtDriver] #900056 08/12/08 05:24 AM
check your ecu. If it's bad, it can take out your ISC resulting in a high idle.
Re: High idle and I'm thinking throttle body [Re: off-roader] #900057 08/12/08 08:45 PM
What does the dash temp gauge say after warmup? The aux FIDLE valve is water temp actuated. No way to change it, but I think they very rarely go bad, so a JY TB may fix it cheap.
Re: High idle and I'm thinking throttle body [Re: fasteddy] #900058 08/12/08 08:58 PM
JY??
Re: High idle and I'm thinking throttle body [Re: off-roader] #900059 08/12/08 09:36 PM
hazy_daze Offline
JY??
Junk Yard...
Re: High idle and I'm thinking throttle body [Re: hazy_daze] #900060 08/12/08 11:30 PM
Junk Yard...
Ahh.. probably right. I see said the blind man. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: High idle and I'm thinking throttle body [Re: off-roader] #900061 08/13/08 12:15 AM
hazy_daze Offline
Junk Yard...
Re: High idle and I'm thinking throttle body [Re: hazy_daze] #900062 08/13/08 02:22 AM
G
generation_one Offline
assuming the screw is all the way in...?
If the water valve is stuck there must be some way to unstick it. I dont know, I havent tried ...yet.
It happenend after cleaning the TB so i guess a little crud found its way in there
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: High idle and I'm thinking throttle body [Re: generation_one] #900063 08/13/08 02:27 AM
G
get out your meter and go through the TPS checks.
Might get lucky
about 200k miles
Re: High idle and I'm thinking throttle body [Re: DirtDriver] #900064 08/13/08 03:11 AM
You say new ISC on order. Do you know the one now is bad? Mine revved low once it went out. I wonder if a fail on another of the three coil-thingies would result is a high idle? Takes all of five minutes to check the ISC with a meter...
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6436 MB (Peak: 0.7686 MB) Data Comp: Off Server Time: 2026-06-10 01:41:29 UTC
