Page 2 of 3 1 2 3
Re: low/rough idle 22re [Re: Jeepeater] #900575 09/15/08 06:30 AM
kewlynx Offline
There is also an amplifier adjustment behind your glovebox for the AC that might need adjusting.
The checkout for the MAF can be found in the '93 FSM sticky'd at the top of this section.
**ubi apis- ibi salus**
Re: low/rough idle 22re [Re: kewlynx] #900576 09/15/08 06:14 PM
Red_Chili Offline
Toyota Section Staffer
Whatever it is, it does not seem to be uncommon. My freshly rebuilt '93 does the same darn thing. <img src="/forums/images/graemlins/angry.gif" alt="" /> I don't have much history with the truck since we bought it needing a timing chain (and as it turns out a complete overhaul) so I don't know the onset. I do know I replaced a TB gasket for a vacuum leak (wrong shape to the gasket) which of course made a WORLD of difference, but didn't address the underlying issue.
I would try the A/C suggestions, except the only A/C I have is in a box on my garage floor, where I bought it from a junkyard! <img src="/forums/images/graemlins/lol.gif" alt="" />
Oh yeah, and except for idle the truck runs really well with Ted's head, valves and cam.
-Bill
Re: low/rough idle 22re [Re: Red_Chili] #900577 09/16/08 06:26 AM
fullhouse Offline
Have you got in the idea of replacing it? I think it needs a replacement.
Auto Zone | Hot Wheels Online
Suspension Lift Kit
Consumer written [url=http://www.cardealercheck.com/]car dealer reviews[/url and ratings
Re: low/rough idle 22re [Re: fullhouse] #900578 09/16/08 04:44 PM
Red_Chili Offline
You mean, the truck? <img src="/forums/images/graemlins/lol.gif" alt="" />
-Bill
Re: low/rough idle 22re [Re: Red_Chili] #900579 09/17/08 06:01 AM
fullhouse Offline
lol! I have a good laugh there . . .If they have money to replace that . . . <img src="/forums/images/graemlins/lol.gif" alt="" />
Suspension Lift Kit
Re: low/rough idle 22re [Re: kewlynx] #900580 09/25/08 11:48 PM
Jeepeater Offline OP
Everything on the MAF checked out. I think. The last check per the manual has me checking E1 - Fc with resistance being at infinity. My ohmmeter read 0. Once, I got it to juggle a few numbers, but it quickly went back to 0. I tested, retested, checked and double checked hoping to get SOMEthing, but it's at zero.
Is this right? I'm really not sure. All of the other tests checked out.
Re: low/rough idle 22re [Re: Jeepeater] #900581 09/26/08 12:05 AM
4Crawler Offline
That is the output that turns on the circuit opening relay (that sends power to the fuel pump), so as long as that is happening, should not be a problem:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml#AFMtesting
Re: low/rough idle 22re [Re: 4Crawler] #900582 09/26/08 12:34 AM
Thanks Roger
It looks like the MAF is good. I never thought I would complain about a part being good, but this is driving me nuts. I guess I'll take a look at the idle up valve posted above and see what I can see. I don't even know where on the motor this thing is. Ugh.
Jason
Re: low/rough idle 22re [Re: Jeepeater] #900583 09/26/08 12:39 AM
4Crawler Offline
Technically, the AFM is not good, since the Fc contact is supposed to open (infinite resistance) when the flap inside is closed. This way the fuel pump is shut off when the engine stops running. But as long as it keeps the fuel pump running, that should be OK.
Idle up valve is on the intake plenum:
- http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/7.html
Re: low/rough idle 22re [Re: 4Crawler] #900584 09/27/08 12:17 PM
P
PCMentor Offline
You can plug off the A/C idle up valve and see if its your prob.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6451 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-07-14 10:47:48 UTC
