1998 KIA Sportage power problems. #900743 08/15/08 09:24 PM
spindj Offline OP
I have a 98 Kia Sportage and it has no power going up hills. Any suggestions?
Re: 1998 KIA Sportage power problems. [Re: spindj] #900744 08/15/08 10:30 PM
SKC Offline
KIA Sportages have problems going up hills on highway speeds. The only thing I suggest would be doing some upgrades for your engine like a cone filter, switching your mechanical fan out for an electrical fan, and getting an aftermarket exhaust system.
Re: 1998 KIA Sportage power problems. [Re: SKC] #900745 08/16/08 06:44 AM
Hydra747 Offline
I would say that you need to check your Cat Converters for clog issues! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1998 KIA Sportage power problems. [Re: spindj] #900746 08/17/08 01:11 AM
wyodriver4 Offline
i have a 96 with a cone filter, and a 2.25 inch straight exhaust and i still struggle up hills. its just one of the down falls of having a 4x4 with halfway decent mileage.
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: 1998 KIA Sportage power problems. [Re: SKC] #900747 08/17/08 01:23 AM
Iron Offline
Before you go adding on to your engine, adding un-needed parts. Try fixing the problem you have first. The Sportage is quit good at hills, just remember you can't do it in 5th, your going to have to gear down if you want to pass on a hill.
As for the lack of power, like mentioned elsewhere check the Cat, they are notourious for falling in on them selves, you could also check the spark plugs and coil packs, and timing belt. But the simplest check is the air filter and fuel filter.
Once you have solved your lack of power issue, then you can add on to your engine for even more.
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: 1998 KIA Sportage power problems. [Re: Iron] #900748 08/17/08 06:12 PM
DennisThompson Offline
If your kia is in good tune and you have a good cat the trick to hills in to shift down before you hit the hill or start loosing speed.
When my Kia was new we took a trip with some friends that had a 93 S10 blazer with a 4.3 V6 and an auto. He kept loosing me on hills untill I started shifting down at the bottom. I could out run him on any hill after that. I flew by him in 4th gear on one hill, he said he had in to the floor in 2nd gear when I went past him. Don't be afraid to your the full range or your tach, the engine can handle it.
Dennis
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6116 MB (Peak: 0.6818 MB) Data Comp: Off Server Time: 2026-05-26 04:56:48 UTC
