timing chain #900827 08/16/08 04:09 AM
A
Anthony_89 Offline OP
hey, I just put a timing chain in my truck... and after i put it all togethor, I realized that the timing chain was quite loose... will this tighten up once I start / run the truck?? the motor is a 22re fuel injected 4cylinder toyota pickup
Re: timing chain [Re: Anthony_89] #900828 08/16/08 04:33 AM
CJM Offline
tensioner .. when oil pressure applied .. is there to do the job . provided , you have a good tensioner ?
83 Trekker SR5
NEW Trekker forum
Re: timing chain [Re: CJM] #900829 08/16/08 04:39 AM
A
ok, thank u verry much... yes, the tensioner is good.. haven't started the truck yet.. put the motor almost all the way togethor, and noticed it. thank u verry much. smile
Re: timing chain [Re: Anthony_89] #900830 08/16/08 04:45 AM
CJM Offline
also make sure .. the top bolt on the oil pump , Is the correct bolt .. VERY IMPORTANT
If not correct , it could contact the tensioner , and impeed it's performance
83 Trekker SR5
NEW Trekker forum
Re: timing chain [Re: CJM] #900831 08/16/08 04:50 AM
A
I believe the top one is short if I remember right.. just to dbl check.. thanks again.
Re: timing chain [Re: Anthony_89] #900832 08/16/08 04:55 AM
CJM Offline
short is good ..
specs eluvate me at the moment !!
long will contact the tensioner . impeeding it's performance .
83 Trekker SR5
NEW Trekker forum
Re: timing chain [Re: CJM] #900833 08/16/08 04:58 AM
A
ok, thats whats in there now.. thank u verry much for your help.. oh, and btw, nice ride. smile
Re: timing chain [Re: Anthony_89] #900834 08/19/08 07:49 PM
Staceman Offline
For Reference.............
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6172 MB (Peak: 0.6989 MB) Data Comp: Off Server Time: 2026-11-04 20:01:28 UTC
