Carburator troubles #900966 08/17/08 09:01 PM
bradne Offline OP
I have an 86 Toyota Pickup with a 22r. Last night I was returning home from the store, I slowed down for a stop sign, put in the clutch and the motor RPMs increased. I let out the clutch and it accelerated very quickly without me touching the gas pedal. I was thinking that the linkage on the carb was stuck, but upon inspection, the linkage was fine. I have cleaned it and done everything else I can think of. I did notice that the boot on the accelerator pump was torn, but I do not know if that could have anything to do with it.
I don't have a tach, but I am guessing that I was pretty close to redlining the engine.
When I was driving home after the problem started, I was doing 50 mph, without touching the pedal. (unwanted cruise control). I could downshift to lower my speeds and it wasn;t too bad, but obviously something is wrong. It ran fine as long as it had a load on the moter (clutch engaged). I rebuilt the carb about two years ago and it has been fine. I suppose I could rebuild it again, but don't really want to if not necessary. I crank it, and it starts fine, then begins to accelerate again after a second or two.
I figure some of the carb experts on the board might have an idea of what sort of problem this is. I am sure it is obvious, but not to me.
Re: Carburator troubles [Re: bradne] #900967 08/17/08 11:10 PM
Sixxgun Offline
did you try checking the choke it could be stuck or maybe the accelartor pump is going bad another thing is the throttle solinoid or the throttle return can be messed up
Re: Carburator troubles [Re: Sixxgun] #900968 08/18/08 01:36 AM
bradne Offline OP
As far as the choke, I changed it to manual a while back. Seems to be fine.
The throttle return looked good to me. How do you test the throttle solenoid? Also, how would you check the accelerator pump itself, besides just visually checking for holes?
I didn't mention, and don't know if it matters, but the fuel level is exactly halfway in the glass where its supposed to be.
Re: Carburator troubles [Re: bradne] #900969 08/19/08 12:20 AM
Sixxgun Offline
Well not sure on both questions I'll have to read my repair manual if you have one it might help you find out what's wrong let me check and I'll get back to you.
Re: Carburator troubles [Re: Sixxgun] #900970 08/19/08 03:05 AM
Scerb Offline
Sounds like you check the obvious things such as sticky linkage. If you're sure thats fine and it started happening while you were driving, I'd say your driver's side motor mount is broken. The motor will torque over and jam the throttle wide open.
I can't think of anything else that would make the carb rev up, seeing as you didn't touch anything before it started happening. If the accelerator pump were blown I'm pretty sure you would have the opposite affect. Also, I am not aware of any throttle solenoid..
Check the motor mount. h <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Carburator troubles [Re: Scerb] #900971 08/19/08 05:32 AM
W
whitetoy Offline
could also be a sticking throttle cable?
Rick
1984 4Runner
Re: Carburator troubles [Re: whitetoy] #900972 08/20/08 12:49 AM
Sixxgun Offline
I did check try seeing if the throttle postion module is messed up or the Dash pot. If you don't have a repair manual they are pretty cheap Hayes or Chilton there anywhere from $15-30 I'll let you know when I refure to the book again on how to test it and adjust it.
Re: Carburator troubles [Re: bradne] #900973 08/20/08 02:45 AM
Richards19884x4 Offline
When you have a broken motor mount, it is not noticeable by checking the throttle linkage while the truck is sitting still. The throttle linkage will seem just fine, along with everything else. It only jams when the motor moves and releases once the torque is gone. I would strongly suggest checking the motor mounts by c-a-r-e-f-u-l-l-y and slowly jacking up the engine. Use a wooden block to spread the load. Observe the motor mount. If the mount separates as the motor rises, guess what? Broken mount. Cheap, and relatively easy to fix on the 22 motors.
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: Carburator troubles [Re: Sixxgun] #900974 08/20/08 04:36 AM
Scerb Offline
Dude, he's got a carburetor. None of the stuff you're talking about applies.
Re: Carburator troubles [Re: Scerb] #900975 08/20/08 07:11 AM
stock87 Offline
The carbs that got an auto tranny stuck behind them had a dash pot.
I know, I know, completely useless info <img src="/forums/images/graemlins/smile.gif" alt="" />
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6381 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-05-29 20:01:42 UTC
