lift kits #901314 08/19/08 09:16 AM
BirdMan89Trooper Offline OP
what are lift kit brands for 89 troopers?
No one in my area has really any idea.
susp. and body.
Commanding the StormTrooper
Re: lift kits [Re: BirdMan89Trooper] #901315 08/19/08 04:42 PM
BigSwede Offline
Independent4x is the only one I know of...
Serenity now!
Re: lift kits [Re: BirdMan89Trooper] #901316 08/20/08 04:28 AM
maxwell417 Offline
The first 1 1/2" is easy. Go to a 4x4 store ask for longer shackles for a Trooper. If the salesman's eyes glaze over and he looks very lost and confused <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> . Tell him it is the same as a Toyota pickup .... that is what happened to me <img src="/forums/images/graemlins/lol.gif" alt="" /> .
Take the shackles home and install, this gets about 1 1/2" lift. Now go to the front, find the torsion bar > follow it back to a bracket > and a big bolt 27mm or 1 1/8" (I think). Squirt some PB Blaster on the bolt, soak it good. Use a jack to take the load off the front suspension. Crank the bolt about 4 turns clockwise. Lower the jack, drive forward and back to settle the suspension. See how level the Trooper sits, Repeat process if more lift is needed. Lift is about 1" for every 4 turns of the torsion bar bolt.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: lift kits [Re: maxwell417] #901317 10/31/08 01:30 PM
dragogt Offline
Will that shackle trick also work for rodeos?
92 Isuzu Rodeo 5sp 4x4
87 F150 2wd aod
83 bronco c6 waiting for a diesel
86 mustang GT T-top 5.0 5sp
83 mustang GT 50 5sp
Aaron
http://www.fordtruckfanatics.com/forum/index.php
Re: lift kits [Re: dragogt] #901318 11/01/08 02:03 AM
Jim_Paget Offline
I am assuming that you are talking about the '92 Rodeo in your signature - in that case, yes, the suspension for all intents and purposes is the same. If you are talking about a later (don't quote me, but I think '98+), then it has a coil suspension in the rear and thus no shackles.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: lift kits [Re: Jim_Paget] #901319 11/01/08 03:51 AM
maxwell417 Offline
Rodeos .... yup. What Jim said.
Re: lift kits [Re: maxwell417] #901320 11/01/08 08:17 PM
dragogt Offline
Sweet tks guy's.
87 F150 2wd aod
Aaron
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6201 MB (Peak: 0.6943 MB) Data Comp: Off Server Time: 2026-05-29 15:01:39 UTC
