NO REVERSE LIGHTS!!! #901388 08/19/08 10:23 PM
9
93jeepcher Offline OP
Failed inspection for "no reverse lamps". Anyone know what could be going on? I have a 93 jeep grand cherokee with the 4.0 L and a automatic trans. Any advice would be greatly appreciated.
Thanks Doug
Re: NO REVERSE LIGHTS!!! [Re: 93jeepcher] #901389 08/19/08 10:23 PM
9
Fuses and wiring are all good too.
Re: NO REVERSE LIGHTS!!! [Re: 93jeepcher] #901390 08/19/08 10:58 PM
DBL_DTY97TJ Offline
Mine's a manual trans, and I don't know if they have any relation to each other at all w/regard to the reverse light switch, but mine has failed several times. On the manaul it's mounted on the outside of the tranny sort of up on drivers side IIRC and is pretty easy to get to and replace. If it functions the same way on the auto you should be able to plug a tester into it to check. OF course the auto is prolly some internal gizmo... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> Good luck.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: NO REVERSE LIGHTS!!! [Re: DBL_DTY97TJ] #901391 08/19/08 11:14 PM
BigJim Offline
It is very similiar on the auto..
Re: NO REVERSE LIGHTS!!! [Re: BigJim] #901392 08/22/08 08:52 PM
JeeperDan Offline
I'm having the same problem, except when I take the switch out and press the button, the lights work just fine. Anyone ever have an SR-4 break internally so that it doesn't contact the switch?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6040 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-06-23 11:35:18 UTC
