looking at buying
#901492
08/20/08 08:01 PM
Found a 1990 Montero LWB LS 3.0 they said it had a blown head gasket. It has the Caution sticker and it is Auto.
WhatÆs the gear ratio and what is the Rig worth? I know 2.6 L have problems with the head gasket do the 3.0L?
And should that worry me that itÆs "blown"
Spike 87 2.6L 5spd Dodge Raider Yota Shackles and Crank,Superwinch Hubs On 33's Thornbird
Re: looking at buying
[Re: Spike]
#901493
08/20/08 08:12 PM
4.62:1 free to $1000 id say. I know 2.6 L have problems with the head gasket do the 3.0L? not as bad as the 2.6, but yeah.... don't overheat one. And should that worry me that itÆs "blown" Uhhhh yeah.. you're gonna have to fix that.
[Re: LandRaider]
#901494
08/20/08 08:22 PM
Ok, so I fix it.
What underling problems would have caused this, and will the over heat have damage other systems?
Is their any previous discussion on the 3.0 blown head gasket.
[Re: Spike]
#901495
08/20/08 08:26 PM
Ok, so I fix it.
What underling problems would have caused this, and will the over heat have damage other systems? Cooling system will prob need attention. Radiator rodded, or recored, new water pump... timing belt also. Is their any previous discussion on the 3.0 blown head gasket.
Yes Lots.
[Re: LandRaider]
#901496
08/22/08 04:17 AM
Use these search terms:
Username = FrankR
Search terms = "head" and "head bolt"
Do that stuff you find in those posts and it will be perfect. Use the quote marks in your search.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6072 MB (Peak: 0.6728 MB) Data Comp: Off Server Time: 2026-06-22 07:34:47 UTCValid HTML 5 and Valid CSS
