trouble with 3 in suspension lift #901642 08/22/08 11:49 AM
kmattinson Offline OP
I just finished putting my 3 in suspension lift from independent4x on my 1990 isuzu trooper. I have also got an alignment. but right when i start out from like a stop sign my transmission and transfer case start shaking. I dont know what is causing it to shake, but I think it has something to do with the drive shaft. If anyone has a clue or has had this same problem please comment back
thanks kyle
Re: trouble with 3 in suspension lift [Re: kmattinson] #901643 08/22/08 03:48 PM
BigSwede Offline
Does it shake before you start to move (as you engage the clutch) or after?
Serenity now!
Re: trouble with 3 in suspension lift [Re: BigSwede] #901644 08/22/08 05:47 PM
Van Offline
If you have a 2 piece drive shaft, more than likely, that is the problem.... you've changed the angle of it with the suspension lift which causes the vibration on take off.
I've learned to live with it for time being.... a lot of people go to a one piece drive shaft.... IIRC, your carrier bearing will wear out faster also.
If you have a 2 piece drive shaft, you MIGHT be able to do as what is describe in paragraph 3 of this article.....
http://www.customtacos.com/tech/index.php?article=27
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: trouble with 3 in suspension lift [Re: Van] #901645 08/23/08 12:37 AM
Gizzy42 Offline
If its already a single drive shaft it could be U-joints. As Van said you changed the angle so if you dont have a carrier bearing it could be bad u-joints being more obvious with the new angle.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: trouble with 3 in suspension lift [Re: kmattinson] #901646 08/23/08 03:24 PM
Yah i do have a two piece drive shaft. But it is an automatic so i dont have a clutch. thanks for that article on carrier bearings. Cause i am pretty sure thats what it is. So i will try that and if that doesnt work i will live with it until i get a one peice. thanks
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6055 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-07-13 04:54:52 UTC
