noisy speedometer cable #901960 08/24/08 04:46 AM
O
olreliable89 Offline OP
Have an 89 4x4 with an irritating racket that comes from the speedometer when weather gets cool and damp. Tried removing myself, Had to put it all back together before I went back to work. What have I done wrong, and can anyone help?
Re: noisy speedometer cable [Re: olreliable89] #901961 08/24/08 05:02 AM
Adam F Offline
How far did you get? It should just pull out of the back of the gauge set. Then unscrew it from the trans. I've heard of people pouring lube down the cable, either spray lube or some type of graphite lube.
97 4R, stock, daily driver
Re: noisy speedometer cable [Re: Adam F] #901962 08/24/08 06:22 AM
O
Got the instrument cluster unbolted from the dash and managed to get my hand far enough behind it to unclip the 2 wiring harnesses going into it. After that, I figured there might be a clip fastening the cable to the cluster, but couldn't get my hand far enough in there to get a hold on anything. Didn't want to get too rough with it and cause myself more problems, so I stoppped there. Wasn't quite sure what I was about to tear up.
Re: noisy speedometer cable [Re: olreliable89] #901963 08/24/08 11:02 AM
Knucklepin Offline
You are going right. The clusters can be a pain in the padded ass sometimes. Just be patient and take your time. You've got to fe-nagle everything a little. Some may disagree with this but: if you have the time to work on it without the pressure of having to drive it some where, I suggest you remove the steering wheel. I know it won't give you any more room behind the cluster or help you see any better, but your arms will be able to move freely and it opens up your work area a lot and uncramps the space. If you are having a hard time, think about how much of that frustration is really because of having to look over, reach around, or reach through while looking around; the steering wheel.
If a man throws a wrench and no one is there to see it; does it still count as pitching a fit?
Re: noisy speedometer cable [Re: Adam F] #901964 08/26/08 01:59 AM
Elbow_Greese Offline
I used a graphite lube on my speedo cable a number of years ago. It eventually broke anyway, but it postponed that for probably 5-6 years.
Removing the steering wheel probably will make it easier to get your arms in there. I haven't had to do that, but I may have had more wiggle room in mine.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: noisy speedometer cable [Re: Elbow_Greese] #901965 08/26/08 06:07 AM
Adam F Offline
I just undid mine a few weeks ago. Its pretty simple. Unhook ALL of your wiring harnesses. There is a release on the clip for the speedo cable located on top. Press down on the top of the cable, and pull back. It will pop off. I can take a pic of it if you need me to.
Re: noisy speedometer cable [Re: Adam F] #901966 08/28/08 04:42 AM
A
anotherjeff Offline
Another trick is to unhook the cable at the transmission, providing some slack to pull the cluster out farther - more room for the hand.
Re: noisy speedometer cable [Re: olreliable89] #901967 08/28/08 07:04 AM
Adam F Offline
Wait...you only unclipped 2? There should be 4
Re: noisy speedometer cable [Re: olreliable89] #901968 08/29/08 03:14 AM
Blitzkrieg Offline
Oil method: Unscrew it from the transmission and work it(loosen bendable retainers) back up and out the engine compartment. Careful not to kink it!! Then oil patiently and freely letting gravity push it through the cable/cover. A little compressd air may help get th oil to where it needs to go quicker. 89 Truck's been quiet for 8-10 years now and 91 4runner lasted about 4 yrs. It's about due for another lube job. May try synthetic oil this time. Good luck
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6254 MB (Peak: 0.7288 MB) Data Comp: Off Server Time: 2026-06-07 06:55:59 UTC
